!!!!!Caution M20 porn inside!!!!!
  • rs4pro3
    • 5808
    #31
    Originally posted by xLibelle
    why not drop map and shoot for alpha?
    that setup looks like it could pose problems
    I'll probably end up running a hybrid MAP/Alpha N setup once I get it on. It's an easy switch with megasquirt ;)
    85 325e 2.7 ITB'd stroker
    • rs4pro3
      • 5808
      #32
      Vacuum manifold plumbed in
      Hey if you want to duplicate it go for it, I will say the parts are very hard to find and not cheap. Most of the Bike throttle body sets sell for $300-$400 and you need 2 sets.
      • einstein57
        • Jun 2007
        • 10780
        #33
        Hmmmm. We have CBR ITB's laying around the engineering club's shop cause we are not allowed to use them on our formula car. And my dad just gave me a spare m20. Wheels are turning. Are you planning on running velocity stacks?
        www.gecoils.com
        • Ray Smoodiver
          • Jun 2004
          • 8809
          #34
          Woah, sick work Ely!
          • TopOfTheLine89
            • Jun 2007
            • 919
            #35
            Damn, that is gonna be fuckin tits once its installed and running. A few things about it are confusing me but it looks great.
            97 tacoma 5 spd 4 cylinder
            2001 330ci 5 speed
            83 733i 5 speed, (FS)
            • So Live
              • 2512
              #36
              Thats friggin awesome dude. I love the set up.
              One or two things i dont like. Id say with N/A the normal worm gear clamps are fine. When you get boosted they might be a problem especially cause there are so many. Id do t-bolts or at least the lined worm gear ones. And the phillips head hardware makes it all look cheap.
              Just my 2c and all in all this is a super gangster project and looks like it has a lot of potential :)
              Good luck and i cant wait to see how it turns out.
              -Chris
              • rs4pro3
                • 5808
                #37
                Ya I'm wanting to try and put some sort of stack on the end of the runners inside the plenum. I'm not worried at all about the worm gear clamps in those areas. On my current setup all the clamps are worm gear and they all hold up fine. I only have one pipe that tends to pop loose, but that's becuase I need a silicone bump hose in that location and I just have a straight coupler. So it has a lot of stress on it. And FYI the Phillips head screws are All OEM BMW parts, I could replace them all with m6 bolts but it's not worth it.
                • e30 gangsta
                  • 3877
                  #38
                  what are you going to do for tuning?
                  Going to run a blend for the signal? Its hard to get a clean signal from itbs with a map sensor.
                  • rs4pro3
                    • 5808
                    #39
                    The whole reason for the vacuum manifold is to try and even out the pulses from each runner so I get a clean MAP pressure to the megasquirt. If that dosn't work then I'll swap to a hybrid Alpha N map, and use the TPS for low RPM/MAP areas.
                    • backtrail69
                      • Jul 2005
                      • 4471
                      #40
                      You can run one of those plastic low pressure fuel filters to help clean up the noise as well.
                      :: PNW Crew ::
                      '87 325 4dr, '74 2002
                      • george graves
                        • 19996
                        #41
                        subscribed
                        Originally posted by Matt-B
                        • SlammedE30
                          • 741
                          #42
                          Looks awesome Ely!! Keep the updates coming!
                          -Ted
                          • Bimmerman325i
                            • 6854
                            #43
                            Damn that gives me an idea too. We've got plenty of old CBR 600 TBs lying around.... If I can fab up a simple adapter to the m20.... gears are definitely turning.
                            Can't wait to see the finished product, this looks awesome!
                            2017 Chevrolet SS, 6MT
                            95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                            98 M3/4/5 (stock)
                            • e30325ic
                              • Dec 2004
                              • 491
                              #44
                              Looks nice, cant wait to see the final results.
                              1990 E30 325ic (sold for more than I paid for it after 5 Years)
                              1995 E30 325e (in progress)
                              1987 E30 325is (totaled)
                              1990 E30 325i
                              1991 E30 318is M50 PWR
                              1996 E36 328ic
                              1997 Z3
                              2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)
                              • rs4pro3
                                • 5808
                                #45
                                Some more ultra rare m20 porn, this may be the first and only time you see pictures of these pistons. 11:1 cr ratio FTW :pimp:
                                Also have on order a bunch of aluminum for making the plenum.
