Ultimate budget build.
  • Danny
    • 14216
    #391
    There is no evidence of detonation on the spark plugs.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      #392
      There will be if you keep driving it. I remember hearing these same sounds in some performance cars that have octane requirements.
      • Danny
        • 14216
        #393
        So any options to get me through to next paycheck? Besides keeping my foot out of it?
        Octane booster?
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #394
          MegaSquirt, Your car is beginning to revolt against the air you are shoving down the plenum, like a supermodel being force fed two big macs a day. Eventually she will pop, or fall off the runway.
          • Danny
            • 14216
            #395
            Well that would be the next paycheck.
              • 34844
              #396
              Octane booster?
              I don't know if it works on M42s, but on the M20 if you disconnect the TPS it will retard the timing. it might make your idle a little wierd though. Of course if it doesn't work you can plug it back in.
              • Danny
                • 14216
                #397
                Doesn't unplugging the tps just make it run at the WOT map or something?
                  • 34844
                  #398
                  no, it runs in the base map, the TPS is basically a idle/cruise/WOT switch. If the computer doesn't see a signal it defaults to the cruise map.
                  • atomic
                    • Jun 2007
                    • 5691
                    #399
                    Ok so there is a weird sound when I'm under boost at high rpms.
                    It sounds almost like little rocks going through the intake or hitting the fender.
                    Any ideas?
                    Deer bits and pieces??
                    :mrgreen:
                    • Danny
                      • 14216
                      #400
                      :mrgreen:
                      • silence
                        • Jun 2007
                        • 1824
                        #401
                        Any ideas?
                        That definitely sounds like detonation. Turn the boost down and see if it goes away.
                        • Danny
                          • 14216
                          #402
                          Autocrossed today.
                          The car is a fucking handful to say the least.
                          A coolant hose got hit by the alternator fins and popped a hole in it, cut it shorter and took the rest of my runs.
                          Vids will be up soon.
                          • Jean
                            • 18228
                            #403
                            Handful in what ways Danny? Are you talking in terms of power delivery or handling?
                            • Danny
                              • 14216
                              #404
                              Its a very linear powerband, no inconsistencies and it pulls very evenly to the top.
                              Its just ALOT of it, its probably the fact I'm not used to it yet.
                              Handles good but feels like I need more rubber.
                              • Jean
                                • 18228
                                #405
                                your suspension and tires good? that's probably the single most important component for events like autocross....
                                So did you fix your detonation issues? running good now?
