Ultimate budget build.
  • Danny
    • 14217
    #106
    Well its not done yet.
    • e30_kid89
      • Apr 2006
      • 489
      #107
      Hey would this work for you??
      It even has a flange for a EWG.
      • Danny
        • 14217
        #108
        Hmm that might actually help alot.
        Thanks man!
        • 2002maniac
          • 4260
          #109
          even with 7psi you will probably exeed the flow of that turbo at higher rpm.
          I'd say you need a T3. You should be able to find one in any decent junkyard.
          • Danny
            • 14217
            #110
            Yes, that is a concern of mine.
            But my buddy who has a Starion (which this turbo came out of) says it pulls hard all the way to the top.
            We'll see.
            • 2002maniac
              • 4260
              #111
              Where do you plan on pulling oil from? Great project btw. Should work out nicely as long as you don't get over zealous with the boost.
              • SamE30e
                • Sep 2007
                • 4319
                #112
                Pull oil from the filter housing. Tap into it, call it a day.
                1985 325e 2.8 Turbo VEMS
                • Danny
                  • 14217
                  #113
                  ^Exactly my plan.
                  And drain will be into the drain plug hole.
                  • e30nub
                    • Jun 2008
                    • 1741
                    #114
                    CHYEAH! Can't wait to see it Danny! Keep up the good work!
                    -Pierre
                    1987 535is
                    1988 325is
                    • deutschman
                      • May 2008
                      • 5958
                      #115
                      this is really cool danny! can't wait to see it! subscribed!
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        #116
                        Originally posted by Danny
                        ^Exactly my plan.
                        I don't think that will work, I think you will need to tap the pan to put a oil outlet tube.
                        Maybe I'm wrong.
                        • Danny
                          • 14217
                          #117
                          Maybe I'm wrong.
                          Well basically I've been watching alot of M50 guys as far as cooling and oil lines go, and I've read that people that go into the oil drain plug actually burn LESS oil than people who tap.
                          The only ones that knock the oil drain idea are ones who haven't tried it.
                          • 550
                            • Nov 2008
                            • 107
                            #118
                            I think with the weight of these cars and handling, that 7-10 psi is going to be a BLAST!
                            My buddy is doing the same in his GTi (1991) and he wants like 20 psi... I told him to stick around 10 ish for a while.
                            I think you'll be happy :) Your car is sick! BTW.
                            • 550
                              • Nov 2008
                              • 107
                              #119
                              As for the oil drain idea, I don't see a huge issue with it. But something that would worry me is back filing into the oil drain tube. I mean I know gravity is working with you, but it seems it could back fill the tube and possibly cause an excess of oil in the turbo.
                              The nice thing about doing the oil drain plug is that if it doesn't work... you can change it with out any major issue. Once you tap and all that BS then it is tapped until you get a new pan or plug it up. Just a PITA to reverse.
                              • Danny
                                • 14217
                                #120
                                You hit the nail right on the head.
                                If I do start to burn oil its also easy enough to tap the oil pan, but this way if I need to go back to stock its real easy.
                                Plus its at a real sharp incline straight down to the oil drain.
