Ultimate budget build.
  • Danny
    • 14216
    #256
    I agree with you, and once I have some cash I will.
    I'm happy with this for now though.
    Its not bad for under a grand.
    • Danny
      • 14216
      #257
      Ok so my turbo's oil seals are fucked.
      Anyone know where I can find the seals?
      The turbo is a Tc05-12a.
      • Danny
        • 14216
        #258
        So I'm leaning out under boost at around 4500 in second gear.
        Looks like I need to turn up the RRFPR
        • 550
          • Nov 2008
          • 107
          #259
          Hmm...
          Search the page for "12a" it will be a td05 rebuild kit.
          • Danny
            • 14216
            #260
            So because I has no money for bigger injectors, I'm turning down the boost a little :(
            To about 6 psi.
            • e30nub
              • Jun 2008
              • 1741
              #261
              To about 6 psi.
              What were you at before? Are you on stock internals? OEM head gasket ect?
              -Pierre
              1987 535is
              1988 325is
              • Danny
                • 14216
                #262
                Yeah everything is stock.
                I was at 7psi but I'll be at about 5.5-6 now so that I don't lean out under boost.
                • e30nub
                  • Jun 2008
                  • 1741
                  #263
                  Sweet, thanks. I want to turbo my m42 now.
                  -Pierre
                  1987 535is
                  1988 325is
                  • Danny
                    • 14216
                    #264
                    Well I went to Sac and back the other day with no issues other than burning a mess of oil.
                    But that will be solved soon with fittings I have coming.
                    It isn't amazingly fast, but its faster than it was before and it has the potential to be faster.
                    • e30nub
                      • Jun 2008
                      • 1741
                      #265
                      Oh yeah, get better videos ASAP!
                      -Pierre
                      1987 535is
                      1988 325is
                      • E30nate
                        • Oct 2007
                        • 1050
                        #266
                        go to pick n pull and get some turbo volvo injectors. theyre like 23lb/hr or something like that. my buddys running them in his m20 with no issues.
                        • SamE30e
                          • Sep 2007
                          • 4319
                          #267
                          5.0L mustang ones could work, but since you have no way to control them you might be going rich off boost.
                          1985 325e 2.8 Turbo VEMS
                          • Danny
                            • 14216
                            #268
                            I'm ok with rich off boost.
                            I'm not ok with lean in boost.
                              • 34839
                              #269
                              what size are stock M42 injectors?
                              neither 19 or 23 # are going to realistically be big enough (I think 19# is the stock size?), although you can get around that somewhat with fuel pressure, to a point. I'd be looking for some 32# injectors if you want some reliability and breathing room. realistically what you need is standalone EMS but you already know that. :p
                              • Danny
                                • 14216
                                #270
                                They're 19 lbs.
                                How big are pinktops from an s52?
                                I have a line on some cheap ones.
