Japandrew73's OEM Euro Restore
This topic is closed.
That hole in the foam is for the M42. Part of the intake sits up so high that there is physically no room for foam, so there is a cutout. A light was never installed in any market underhood that I have ever seen.Comment
REALLY?! The shop I help out has a couple of these laying around IIRC. My boss is a neat freak and keeps everything. I'll see if I can snag some if he doesn't know what he has. MUHAHAHAHA!-Pierre
1987 535is
1988 325isComment
lol, I was just messin with Andrew when I posted that. (although a underhood light would be nice)turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.Comment
Made some more progress on the engine harness today. All grounding points were filed down with needle files so there isn't any grounding problems. All broken plug housings were replaced, and a broken fuel injection relay plug housing was also replaced. Also got a new dipstick.
Old relay plug housing
New one (middle) connected to the others like the plug housings go together nice and neat. Relays themselves were also cleaned up
The only cracked plug housings besides the relay were the fuel injector plug housings. Every one was broken.
Old on left, new on right
The new shape of the plug housing that BMW has replaced is much easier to disconnect than the old style.
Also realized while taking the old ones off, that each had it's own tiny gasket. I was worried I'd have to go back to the dealer and order the gaskets, but the new plug housings actually come with a new gasket inside, pretty convenient
Also made a bit more progress on the instrument cluster today. In the feat to keep my instrument cluster NCPT (Non-coding plug type, with the Si board lights 5 green, 1 yellow, 3 red) I realized the reason my tach wasn't reading as high as it should, is the wrong coding peg is in the tach. Now, even though the early clusters are claimed to have no coding plug, there actually is a coding "peg" if you want to call it that. This little plastic peg looking thing with a number on the bottom. I know for sure of 3 different numbers on the bottoms. That number designates the 4-cyl, or 6-cyl feed to the tach. Besides the numbers, there are different cutouts that touch the right pins on the tach, although it's much easier to differentiate by using the numbers on the bottom.
On the left you have the 03, this is for the 4-cyl. On the right you have the 10, this is for the 6-cyl. I replaced my original 10 with the 03 and now the tach reads as should! Very nice to have an operable tach after not having one for 5 months! What confuses me though, is I've seen a picture of a coding "peg" with a 01. So that means there is a 03, a 10, and a 01. A 4-cyl, a 6-cyl, and what would the 01 be for??
Anyways, now that the Si board is working, and the tach is working, all that's left are the temp gauge and the gas gauge. Those are for another day. But once those are fixed, I'll be finished with the functional part of my cluster! But not the aesthetic part...Comment
So are you getting this done at a shop, or doing it in your driveway?...
i MIGHT do something slightly similar to this. I found a rust-free 91 325i auto with 198k, its been sitting for about 5-10 years, with the valve cover off and misc parts ripped from it . I also found a running 325i convertible 5 speed for 500 with 160 k. i hate verts, so I might swap everything over and make that my senior project. But I have access to a lift for free.
What is your budget for this? and how are you going to afford this? I only ask because i want to do something similar to this. And your very inspiring seeing as we're around the same age.1985 325e M50TU(Sold)
1991 318is Slicktop (Sold)
1990 325is Brilliantrot S50/5 Lug Swapped.
1992 525i Manual shitbox Winter BeaterComment
