Japandrew73's OEM Euro Restore
This topic is closed.
  • Pinepig
    • Sep 2007
    • 1811
    #766
    This is over at Emotech,
    Why is this kid revered, his moral fiber is lacking hardcore.
    Sept 6th to have your 333i clone done, BWHHHAAAAA, better get a bus pass kid.
    • Asbradley21
      • Jun 2008
      • 1938
      #767
      Who the fuck post this?
      Good luck Andrew. Can't wait to see it.
      S54B32 swap in progress. Status: Getting There
      • Japandrew73
        • 2164
        #768
        Thank you. Obviously, the deadline is extended. :)
        • Japandrew73
          • 2164
          #769
          Originally posted by Matt-B
          what is the part # for gas door boot thing? dealer ordered the filler neck instead :sad:
          part number on those 2 pieces?
          my shit is broke there to
          Originally posted by Jean
          Also check the fuel hose going to the tank on the passenger side.... probably on it's last leg as well..
          16121180402 hose
          51711884358 gas door boot
          You already asked. Jean kindly answered.
          http://www.realoem.com/bmw/showparts...61&hg=41&fg=25
          Part number 14 in this diagram, the number is 51711884358
          • Japandrew73
            • 2164
            #770
            oh didnt even see that, thanks though...
            they had the # 2 off i think and accidentally ordered me the filler neck.
            thanks andrew....
            donor was a good buy :)
            hah no problem thank you. I have a few updates, but no pics. I'll wait until I'm off work and can upload pics and then I'll spill. Nothing too big yet.
            • Jparkr
              HR Admin
              • Jan 2006
              • 3494
              #771
              he is just posting to post.
              1987 PRO-3 car /1990 325is (2.7i Concours)
              • Pinepig
                • Sep 2007
                • 1811
                #772
                A guy that won't fuck others over that are trying to help me AND who could pull something off like the kid want's to in the time frame he desires.
                Slap a headgasket on the damn thing and drive it while you set up all the small shit for your swap.
                • Japandrew73
                  • 2164
                  #773
                  Before I realized I had a swap to do, I had a few things on order from the dealer. Just little things that bugged me.
                  The latch and knurled knob for the jack were corroded and gross.
                  So they were replaced
                  Also I finally got to installing the rear foglight light on the instrument cluster. Now whenever the rear fog light is turned on, the instrument cluster lets me know. This pic is with the rear and front (if I had front) fog lights turned on.
                  Also am going to make an effort to get my instrument cluster fully functional so there is less confusion when the motor is swapped as to how to adapt it to my cluster. It's better to get the cluster working with my current motor, and then do the swap and make the necessary provisions, rather than to have a faulty cluster, do the swap, and not know whether I'm doing the provisions right while I have a faulty cluster... if that made sense.
                  So trying to stay period correct, I got an early, fully functioning Si Board (5 Green, 1 yellow, 3 red) and installed it. Still have some work to do on it however.
                  Anyways, the motor comes out the day after tomorrow and then the cleaning begins! :)
                  • e30edward
                    • 777
                    #774
                    Awesome can't wait!
                      • 37833
                      #775
                      If you plan on having a working tach with the M30 you're going to need a 87+ cluster with a coding chip.
                      Grover Beach, California
                      BimmerHeads.com
                      • reelizmpro
                        • 9547
                        #776
                        Hey I was thinking, shouldn't you have euro H4/H1's instead of ellipsoids on your OEM euro restoration? along with the non cut out euro grills? Just a thought.
                        88 M3 - LACHSSILBER
                        89 M3 - ALPINEWEISS II
                        • downernsp
                          • Mar 2008
                          • 1932
                          #777
                          Nice work keep up the great JOB.
                          • Jean
                            • 18228
                            #778
                            Yep, told him that before :) Maybe he'll have his cluster/tach re-done for a 6 cyl engine by that cluster place he mentioned earlier in this thread though....
                            Andrew - found this the other day http://www.motortopia.com/vehicles/v.../i/triplethree
                            Are you going to to sell your tranny and find a dogleg version? Also have you already upgraded your rear end or are still running a small/open 3.64?
                            Specs
                            Engine 6 cylinder (M30)
                            Displacement 3210cc
                            Power (max) 145kW @ 5500rpm
                            Torque(Max) 285N.m @ 4300rpm
                            Transmission 5 spd Getrag Sports “Dogleg”
                            Final Drive ZF limited slip (2.93:1)
                            Performance 0-100km/h (0-62mph) 7.23s Top Speed 231 km/h
                            (As tested by Car, Jan 1986, coastal conditions, test crew of two and full tank of fuel)
                            Factory Options
                            Air Conditioning
                            M Technic 1 Aero kit
                            M Technic 1 Steering Wheel
                            296mm Alpina Big Brake Kit + ABS
                            • Japandrew73
                              • 2164
                              #779
                              Actually, the motor is an '86 so i'm pretty sure this is not the case, however I could be wrong. This motor has no Check Engine light either.
                              Actually it was an option for some early models to have ellipsoids, but they were made by Bosch at this point and not by Hella. However H1/H4's will be the goal, but with integrated city lights.
                              Yep, told him that before Maybe he'll have his cluster/tach re-done for a 6 cyl engine by that cluster place he mentioned earlier in this thread though....
                              Thanks for the link Jean, I've learned all about the 333i. I have a folder full of hours worht of research about it. I know the specs I have in this car aren't up to par with the 333i specs yet, but for now I'm just going to get the engine in the car, and then spec it to Alpina settings.
                              My instrument cluster will be going to North Hollywood Speedometer for an Alpina replica job at some point. The diff I have in my car currently is the factory 318i one, but the donor car comes with a very well running 3.25LSD. That will be switched with the correct LSD at some point also.
                              • gazellebeigem3
                                • Jun 2005
                                • 3712
                                #780
                                in what year did they option a bent fuel needle? alpenis maybe?
