1990 325is oem+ Now turbo (Video)
  • Cablanedo
    • Jan 2016
    • 283
    #76
    This build is something else. The detail like everyone else is saying is great and I’ve been following you since day one!! I just love the commitment you have to fixing everything little thing that’s not up to your standards with the car. Really inspirational. Anyway, looking forward to more updates
    • Iloveboost
      • Sep 2019
      • 136
      #77
      WoW thanks man , this is really fun to read ! It mean you don’t just look at the picture but you also read !
      i do my best for this car and it is great that you guys appreciate the good work !
      • Iloveboost
        • Sep 2019
        • 136
        #78
        little update for today !
        at first, as someone ask about the ''dye' for the steering wheel, here it it
        i do not expect long life result with the product but i give it a try !
        in the last few days i made myself a front strut bar . i know they not cost much but for me ( canadian dollar) it most likely about 160-180$ for the basic one like garagistic. so i made one for about 25$ paint include.
        still working with cardboard for the template hahaha!!
        the grinder do nut cut like a plasma cutter so the first result is little rought,
        i bolt them together to trim it as 2 identical pieces
        then bolt them in place and start working on the tubing.
        to bend the tube, i went the easy way since i do not have mendrel bent machine at home lol...
        make a groove about 1/2 deep of the tube , it was very easy to bend ( welding back when achieve the good angle)
        for the end of the tube, to fit on the top plate , i still go for the easy way since i am not so good with guess and imagine wich angle to cut..
        cardboard template level 2 !
        it work perfectly! nice snug fit
        tack everything in place, then remove it to finish the welding and prep it for paint.
        i have paint it red with MATTE clearcoat ( same as the rear one )
        install it
        pretty proud of the result !
        the weld are sure not TIG , but should be strong enough !
        this is 3.5hours godd invested !
        • jsta1109
          • Jun 2015
          • 172
          #79
          Wow... for $25 that's a decent result. Following this thread makes me feel really lazy.
          IG: https://www.instagram.com/josh.stacey/
          Flickr: https://www.flickr.com/photos/133952286@N03/
          • Tzantushka
            • Nov 2018
            • 390
            #80
            Impressive.
            And impressive on the 3D Cardboard Aided Design!
            E30 320i vert
            But daily drive is Volvo V60 Polestar
            • Iloveboost
              • Sep 2019
              • 136
              #81
              little update !
              i refresh the look of the front grill by :
              clean them
              scuff it with sotchbrite
              adesion promoter
              trim black by SEM
              reassemble the centergrill
              i receive my DEPO new headlight. i know they are not like the HELLA smiley but for half the price, ( new vs used) i give it a try !
              ( for those who want to know. they look cheap.. not quality and solide to compare with oem hella or bosch..)at least the lens are Glass !
              i had to swich the conector from sealbeam to 9005/9006.
              good thing i have some connector laying around in the garage !
              i give a little coat of trim black on the moulding on the bumper the lazy way.. ( not remove them)
              ( did the rear one as well)
              i polish the front flasher lens.
              the picture show the before ( 270000 km of use ) vs the polish one
              sanded - 800-1000-1500-2000 then polish it !
              the front end came out good looking !
              i want to mention that almost everything i do for the ''look'' of the car(exept the rust repair than i do 100% correctly), i dont do it by my standard. i mean. since i will change the color of the car next winter, i dont go all in with the paint and touch-up here and there . i use economy materiel to have the eye-catching good looking.
              i still do thing the good way .
              in the end, the e30 look incredible in compare of many others.
              when i will do the color change, i will do the thing the way i want with better product and no corner will be cut !
              last thing. i spend little time in the past few days to look about other build. some are crazy ! like jordan one and 2-3 other who almost do the same. it amazing ! i wish one day i could do the same !
              • Iloveboost
                • Sep 2019
                • 136
                #82
                Just making test with tapatalk ( since day one I make this thread by going with my PC ) If this work it will be very easy/faster for me to make the updates !
                • efficient
                  • Feb 2012
                  • 3312
                  #83
                  very nice makes me want to work on my e30 that just sitting.
                  • Pootis
                    • 636
                    #84
                    I've always been tempted to pickup a set of depo lights but heard quality and cutoff are bad. Not sure I'm digging the color matched grill but interested to see it installed. That's the first thing I have questioned in your build so far. Excellent work
                    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                    • Iloveboost
                      • Sep 2019
                      • 136
                      #85
                      The Depo light quality is not as good as oem but certainly much better than any « eBay style » other light.
                      Depo is still a good brand on the aftermarket light world .
                      for the price , I can’t complain . If they don’t last long . I will certainly buy some froid use oem ( hope to not learn that way haha)
                      for the grill , I’m not sur about it too .
                      My chrome one was very used and stonechiped.
                      i bought some all back one and didn’t like the look .
                      sinxe i cant make chrome by my self , the easy way was to paint it . if I can’t live with it , I will endure it for this summer and when I will make the complete color change I will add the front grill in the (already very long) list of new parts to order !
                      i will update bette view picture when I will finish polish it ( explain later )
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5277
                        #86
                        FYI most Hella smiley low beam parts interchange with the Depo smileys. The Depo is pretty much a direct knockoff of the Hella part, I think nearly all of it is interchangeable
                        Originally posted by priapism
                        Originally posted by shameson
                        • Iloveboost
                          • Sep 2019
                          • 136
                          #87
                          Very little update ! I have polish the car (counpound) . It was very needed because the car has accumulate lot of paint fume during the winter even if I have protected it . So I wash the car with solvent mask every black thing, Buff it with my makita and then wax it. It was not a real 3 step counpound. I did only one step since 3step was not needed + I hate doing this haha ! I have come to conclusion that maybe I will not be able to get fresh new wheel and tire for the season opening so I give a little refresh to my oem wheel . I know it’s on winter tire but there almost gone and I planed to get new wheel buy the end of April . I do not have full picture by now but here is how it sit ! I will take the car outside to get better picture of the whole car in the next days ! Im in the process of deleeting the DRL. Since my car is Canadian , the drl is factory install . I want to get rid of it. Can someone tell me how ? I have made many research without result. Thanks !
                          • Iloveboost
                            • Sep 2019
                            • 136
                            #88
                            I have taken few minute to get the car outside for better all around picture ! I am very happy about the result of all my work ! Difficult to believe that more than 300hours has been put on the car when I compare to the « before » . All the little thing I have change make the car looking prefect to my taste( beside the wheel that I will change soon)
                            • Albie325
                              • Jul 2016
                              • 515
                              #89
                              Car looks fantastic, and looks like it's finally warming up a bit weather wise. Hope you can get out and show it off now
                              '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                              Albie325 Build Thread | Albie325 COTM Jan 2021
                              • Iloveboost
                                • Sep 2019
                                • 136
                                #90
                                The last 3 pictures are the « before »...
