1990 325is oem+ Now turbo (Video)
  • Iloveboost
    • Sep 2019
    • 136
    #121
    Originally posted by Northern
    What did you use for paint/clear on the bumper and valence? The colour match looks very good!
    Yes the color match is very acceptable .
    i have use Ppg water base paint and 2k clearcoat.
    Both shoot with spray gun .
    ive been car painter for 8-9years. It helps !
    • luckybk
      • Jan 2019
      • 127
      #122
      bummer about the repair, but it almost seems that you're happier if you have something to repair...
      • Iloveboost
        • Sep 2019
        • 136
        #123
        haha , I can clearly tell you that , when i broke it , i was not happy at all hahah!
        • 2mAn
          Señior Mod
          • 21083
          #124
          Love this progress, excited to see the turbo progress. What are the plans there?
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Iloveboost
            • Sep 2019
            • 136
            #125
            Thanks !!
            plan number one : trying to keep some reliability .(HAHAHA)
            seriously. My turbo plan is :
            pushing around 14-16 psi with hx35w turbo
            fmic
            external wastegate
            custom intake/piping/exaust
            Oem bmw head gasket
            Arp head stud
            and hope to have something between 300-350 whp an tq.
            finger crossed!
            • Iloveboost
              • Sep 2019
              • 136
              #126
              Lately I have dismantle the engine partially in order to install the new Oem head gasket and ARP head stud I have to be honest, I’m little scare to put back together everything and make it run ! Especially all the cooling and vaccum line . But I keep in mind that I will have my actual engine (one in the car) to help me ! First time to me to open an engine . Is this mark (cross marks) on the cylinder mean that the engine has been refresh or it can from the factory? Reminder , this engine only avec 161000km ! Head look very clean ! Envoyé de mon iPhone en utilisant Tapatalk
              • Iloveboost
                • Sep 2019
                • 136
                #127
                I have start to clean parts from the engine . Everything is so messy greassy ! While putting this engine turbo , I want to make it as clean as possible and the most important , LEAK FREE ! Will it be possible ? I will change pretty much every gasket/seal/oring that pass through my hand. For the turbo oil feed , thread was added to the banjo bolt. (Fitting is 1/4 ntp to An4) Misc part from the engine refreshed with satin black . I also wrinkle paint my valve cover with great result! When the paint will be dry , I will sand the the paint off the line and BMW!
                • Iloveboost
                  • Sep 2019
                  • 136
                  #128
                  After sanding the top of the cover with : 80-120-180-320 grit , the result is awesome ! Very happy about it !
                  • Glaede
                    • Oct 2007
                    • 138
                    #129
                    Looks really good!
                    Did you sand it by hand/with a block or? What paint did you use for the wrinkle look?
                    • Iloveboost
                      • Sep 2019
                      • 136
                      #130
                      Thanks !
                      i use « VHT wrinkle paint » spray can . Very easy to use
                      fornthe sanding i did it by hand with bloc . Took me about 30 min to sand , not so long for the result!
                      • mike.bmw
                        • Dec 2015
                        • 1777
                        #131
                        Those parts cleaned up nicely. And that valve cover looks awesome!
                        • Iloveboost
                          • Sep 2019
                          • 136
                          #132
                          Thanks Mikes ! It was a very messy job get everything good and clean ! I finish to prep the head .( cleaning, old gasket removal , surface prep for new gasket) The bloc is also ready to have the new Oem HG. I have prep de bloc with 3m bristle disk. I ensuite up using the white one which is equivalent to 120grit or so. Those bristle disk are very hard to find.. if it can help , here is the 3M part Number :07528 The oil pan came back from the welder. -An10 bung welded for oil drain Rear main seal replace and back of the engine cleaned! Fresh new oil pan gasket And to secure my work , new tool coming in the tool box ! Digital gearwrench torque wrench I hope I doing thing right .. this is my first engine build , definitely a big learning expérience !
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5284
                            #133
                            cylinder walls and head look really good!
                            Originally posted by priapism
                            Originally posted by shameson
                            • Iloveboost
                              • Sep 2019
                              • 136
                              #134
                              Yes ! I think they are good, engine only a have 160000km and head as been full rebuilt+ machined 3000km ago . I didn’t make de head resurfaced since it only have 3000km . I cross my finger that she’s not warped! Today I have put de head back on Chase thread on the bloc Lubricated Arp stud with their « ultra-torque » Thread them handtight Put the head Put the washer and nut Torque them 3 time in recommended sequence up to 70 ft/lb Brand new Graf water pump , gates belts and all the misc things related to water pump
                              • paynemw
                                • Dec 2015
                                • 439
                                #135
                                you better baffle that oil pan and put in a crank scraper while the engine is out. Don't screw that engine build by forgetting those two key parts.
