DTM style trailing arm project.
  • gnmzl
    • Jun 2012
    • 204
    #31
    You just made a dream come true. Bravo
    '85 Alpine Weiß 2-door with m20b30 ground up build
    • cwlo
      • Sep 2015
      • 131
      #32
      Really nice execution! Did you weigh them compared to stock?
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #33
        Now you just need new sway bar end link bushings
          • Jun 2010
          • 2796
          #34
          Originally posted by R3VM3UP
          On a trailing arm suspension the wheel will move front to back in the wheel well a bit during normal suspension travel. I don't think that the adjuster at the outer point will make much of an impact on overall position, though I do see how putting it inboard would make it move slightly less. My guess is it was positions on the outer point for easy adjustment in the DTM car.
          It doesn't move much forward and back throughout its travel.
          If someone has really close clearance between the wheel or tire and fender lip, then moving the wheel around for alignment might cause a problem.
          Of course the wheel also moves inboard/outboard when toe is adjusted at the inboard pivot, so that might actually be worse for fender lip clearance.
          • silnc
            • Feb 2015
            • 90
            #35
            I did, they are +/- 1lb of stock These prototypes were made from thick DOM that we had in the shop. Future ones will be made out of chromoly so it can be thinner/lighter. Still not bad considering they're reinforced. It's really the knuckle that makes it heavy though. Sent from my Moto G (5) Plus using Tapatalk
            • silnc
              • Feb 2015
              • 90
              #36
              Dude I know lol. I didn't even think about them until I pulled my old arms off... Puke Sent from my Moto G (5) Plus using Tapatalk
              • moatilliatta
                • 6151
                #37
                Sway bar link seems to be an aggressive angle.
                Hows fuel filler hose clearance look on passenger side?
                @Zakspeed_US
                • silnc
                  • Feb 2015
                  • 90
                  #38
                  Originally posted by moatilliatta
                  Sway bar link seems to be an aggressive angle. Hows fuel filler hose clearance look on passenger side?
                  The angle is pretty good when the car is sitting, better than the stock trailing arm when lowered. The filler hose sits on the passenger arm, puts very little pressure on it. Though if this car was "slammed" it would be a problem. Sent from my Moto G (5) Plus using Tapatalk
                    • Jun 2010
                    • 2796
                    #39
                    The suspension is at full droop. Look at the sway bar arms... they're level-ish at ride height.
                    Thought about engineering a knuckle? In my head I see a lathe turned part that would accept the wheel bearing and have a shoulder for seating/locating a piece of laser cut plate that would mount the service brake, mount the parking brake and have lugs for welding tubes. Getting the shock mount right would be a little fun.
                    • silnc
                      • Feb 2015
                      • 90
                      #40
                      The suspension is at full droop. Look at the sway bar arms... they're level-ish at ride height. Thought about engineering a knuckle? In my head I see a lathe turned part that would accept the wheel bearing and have a shoulder for seating/locating a piece of laser cut plate that would mount the service brake, mount the parking brake and have lugs for welding tubes. Getting the shock mount right would be a little fun.
                      There have been ideas about making a knuckle, trying to land it at a good price point is the issue. Sent from my Moto G (5) Plus using Tapatalk
                        • Jun 2010
                        • 2796
                        #41
                        That's always the issue. That's where being smart about the design comes in.
                        • silnc
                          • Feb 2015
                          • 90
                          #42
                          Update on the arms, been driving daily on them for awhile now, no issues. Had to re-torque the strut tower bolts after settling but other than that everything works fine.
                          Sitting at about -1 camber for daily use and i couldnt be happier.
                          • silnc
                            • Feb 2015
                            • 90
                            #43
                            Here it is sitting on the ground Sent from my Moto G (5) Plus using Tapatalk
                            • moatilliatta
                              • 6151
                              #44
                              Whats next?
                              @Zakspeed_US
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #45
                                Is there a reason why the adjuster is positioned at an angle to the mounting point on your jig? Vs perpendicular?
                                Shadetree30
