E30 M3 Vert
  • Cptcarisma
    • Jan 2011
    • 466
    #46
    Oooooooooooo!!!!!
    Aaaahhhhhhhhhhhhh!
    CAPP
    • Javier h
      • Sep 2007
      • 1189
      #47
      Word of art. Cant help to think of Vlad's white/red combo vert back in the days which looked great in pictures.
      • Mike36
        • 1079
        #48
        Any photos of the interior yet?
        • Tzantushka
          • Nov 2018
          • 389
          #49
          Wet sanding the engine bay - that's dedication!
          E30 320i vert
          But daily drive is Volvo V60 Polestar
          • 968Reckless
            • May 2013
            • 1095
            #50
            Just what i've posted above. Just got the top back so when that goes on ill put the interior in.
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
            • 968Reckless
              • May 2013
              • 1095
              #51
              FSF and rack are in, ended up going with a 330i purple tag from the rackdoc.
              Click image for larger version  Name:	49437274761_f2f3f2e5ab_z.jpg Views:	0 Size:	95.3 KB ID:	9908516
              modified 944 booster pictured.
              Click image for larger version  Name:	49596180111_e69f2ebf4d_z.jpg Views:	0 Size:	80.1 KB ID:	9908517
              Keeping the stock sway bars for now, front is plenty big. Blasted and painted with new hardware.
              Click image for larger version  Name:	49596982882_ac3445a906_z.jpg Views:	0 Size:	67.6 KB ID:	9908554
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
              • 968Reckless
                • May 2013
                • 1095
                #52
                After i was able to get the new front frame in i started working on the suspension.
                spindles were cut and sleeves were hammered on.
                Click image for larger version  Name:	49437497462_8bf8bd127b_z.jpg Views:	0 Size:	92.1 KB ID:	9908520
                Welded everything together and painted.
                Click image for larger version  Name:	49596180476_8dabb4515d_z.jpg Views:	0 Size:	86.6 KB ID:	9908521
                Click image for larger version  Name:	49596426117_4d81483f2c_z.jpg Views:	0 Size:	62.8 KB ID:	9908522
                finished product
                Click image for larger version  Name:	49596179331_515cb3aa30_z.jpg Views:	0 Size:	62.6 KB ID:	9908523
                /// MTech Belts ///
                S52 BUILD
                M3 VERT BUILD
                • saucers
                  • Apr 2016
                  • 273
                  #53
                  drool!
                  • rzerob
                    • Jun 2013
                    • 2315
                    #54
                    How have I missed this build? Subscribed. Great job OP, keep it up.
                    • 968Reckless
                      • May 2013
                      • 1095
                      #55
                      thanks guys!
                      /// MTech Belts ///
                      S52 BUILD
                      M3 VERT BUILD
                      • rjmcdermott81
                        • Oct 2014
                        • 563
                        #56
                        Originally posted by 968Reckless
                        Motor came out next, this was a milestone because the bay had a lot of work to be done.
                        In between the strip down i worked on some interior stuff. Rebuilt the cluster with new gears, rings and paint. Polished the lens, matched the miles to the motor and went with a 9k tach centered.
                        If you don't mind me asking. Where did you get the trim rings for the cluster?
                        Build Thread: Ryan's Hennarot 318is
                        COTM Aug 2019
                        • 968Reckless
                          • May 2013
                          • 1095
                          #57
                          I get all my trim rings off ebay and usually pay around $13. They come in the standard aluminum finish but these ones i ended up painting red.
                          /// MTech Belts ///
                          S52 BUILD
                          M3 VERT BUILD
                          • rjmcdermott81
                            • Oct 2014
                            • 563
                            #58
                            Awesome thanks. I'm going to have my cluster apart again soon and I'm going to do something similar.
                            COTM Aug 2019
                            • 968Reckless
                              • May 2013
                              • 1095
                              #59
                              At this point im pretty much caught up with where im at on the car. Found some random photos of the small stuff i did.
                              All new brake lines bent and flared
                              Click image for larger version  Name:	49596179391_0de304a5f1_z.jpg Views:	0 Size:	91.7 KB ID:	9909024
                              had to extend the filler neck to accommodate the box fender. Purchased a second hose and cut the middle section out, hopefully it holds up.
                              Click image for larger version  Name:	49596179926_bc06d210df.jpg Views:	0 Size:	34.3 KB ID:	9909025
                              nice and fresh paint + backup camera because why not. My car came with 2 different keys so while everything was being painted and rebuilt the 3 exterior lock cylinders and matched them to 1 key.
                              Click image for larger version  Name:	49439094366_5930b7e7be_z.jpg Views:	0 Size:	49.4 KB ID:	9909027
                              /// MTech Belts ///
                              S52 BUILD
                              M3 VERT BUILD
                              • 968Reckless
                                • May 2013
                                • 1095
                                #60
                                I've been slowly working on my trunk setup as i want to have a clean area with usable space. Added some sound deadening material and cut a new floor. The only pieces exposed will be the tank and management. Amp, comps, soft lines and wiring will all be tucked into the the spare wheel well.
                                Click image for larger version  Name:	49439096011_4c3d2e5c86_z.jpg Views:	0 Size:	81.8 KB ID:	9909036
                                Click image for larger version  Name:	49437275216_bf19bcd377_z.jpg Views:	0 Size:	113.3 KB ID:	9909037
                                Click image for larger version  Name:	49596180206_4dee9a4e11_z.jpg Views:	0 Size:	96.4 KB ID:	9909038
                                /// MTech Belts ///
                                S52 BUILD
                                M3 VERT BUILD
