E30 M3 Vert
  • bradnic
    • Jul 2012
    • 3554
    #91
    late to the party.. as usual SUB'D
    great work!
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • Staszek
      • 2533
      #92
      Originally posted by 968Reckless
      thank you
      i rarely sell lol
      Trade lol :)
      • 968Reckless
        • May 2013
        • 1095
        #93
        Ended up going with Chase Bays front brake line setup for OEM master cylinder. I've bent front lines before and it can be a real pain with all the angles in such a small area, not to mention you have to make sure nothing is rubbing on the engine. I do have the e38 7 series master and a 944 booster but everything seems to fit as it should. Instead of running behind the engine the soft line attaches to the front subframe which is nice. I'll update this after i run some fluid through it and mess with the regulator.
        Click image for larger version  Name:	49983927038_965162a2a0.jpg Views:	0 Size:	53.5 KB ID:	9930833
        Click image for larger version  Name:	49983743083_23007446dc.jpg Views:	0 Size:	49.5 KB ID:	9930834
        Was also able to get the windshield lock strip in this weekend but i did have to call a professional in to do it. I've done this 3-4 times but i've always used the original gasket, lockstrip and glass. I'm note sure if i wasn't able to get it done because of the new gasket and lockstrip or because the aftermarket glass wasn't made correctly.
        Click image for larger version  Name:	49984264431_06f261dcc3.jpg Views:	0 Size:	45.2 KB ID:	9930835
        All the polished trim was wrapped satin black and new gaskets were installed. Nothing like fresh gaskets!
        Click image for larger version  Name:	49984521412_9789140622.jpg Views:	0 Size:	39.4 KB ID:	9930836
        /// MTech Belts ///
        S52 BUILD
        M3 VERT BUILD
        • 968Reckless
          • May 2013
          • 1095
          #94
          Taillight test fit
          /// MTech Belts ///
          S52 BUILD
          M3 VERT BUILD
          • 968Reckless
            • May 2013
            • 1095
            #95
            Only a minor update as i've been working on every car but this. Door cards are in and looking good, made some good progress on the custom hvac setup as well.
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
            • Stan
              • Jul 2019
              • 774
              #96
              MAN YOU DO INCREDIBLE WORK! Outstanding, you will have a $70,000 car when you are done!
              • Stan
                • Jul 2019
                • 774
                #97
                Started polishing all the glass with cerium oxide, trying to remove 30 years worth of scratches is difficult.
                Click image for larger version Name:	49610906027_89caa055fe_z.jpg Views:	0 Size:	116.3 KB ID:	9910715
                Painted the window trim while i was working in the area. It would have been much easier to do this before the car was painted but i completely forgot.
                Click image for larger version Name:	49644008166_fd2acc7cce_z.jpg Views:	0 Size:	78.8 KB ID:	9910716
                When you polished with cerium oxide, was it by hand or machine polisher?
                If by machine, random orbital like from Griots? If yes setting 4?
                THANK YOU
                • 968Reckless
                  • May 2013
                  • 1095
                  #98
                  THANK YOU
                  I used a 3" cotton wheel on a drill, you don't need a lot of speed and pressure to get results. I'm sure you can find some videos online about the process.
                  /// MTech Belts ///
                  S52 BUILD
                  M3 VERT BUILD
                  • Stan
                    • Jul 2019
                    • 774
                    #99
                    Thanks, I hope you are continuing to make progress
                    • 968Reckless
                      • May 2013
                      • 1095
                      #100
                      Slow progress since i decided to start/finish the 2002 quick. Now that i'm done with that i can put my focus back on the vert.
                      Interior has been installed and the radio/hvac layout is finished. I'm still messing around with painting or vinyl wrapping the panel but the pictures show it with some black vinyl i had laying around. Nothing is 100% secured in the pic so don't judge me lol.
                      /// MTech Belts ///
                      S52 BUILD
                      M3 VERT BUILD
                      • Stan
                        • Jul 2019
                        • 774
                        #101
                        I have a gauge cluster panel I bought but do not want.
                        $55.00 shipped.
                        You do terrific work!
                        • 2mAn
                          SeƱior Mod
                          • 20812
                          #102
                          No finished pics of the 2002?...
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          -2006 Volkswagen Jetta TDI
                          Make R3V Great Again -2020
                          • 968Reckless
                            • May 2013
                            • 1095
                            #103
                            $55.00 shipped.
                            Not sure what you mean by gauge panel cluster and thank you!
                            Honestly i don't have any, will get some this weekend when i put it away for the winter.
                            /// MTech Belts ///
                            S52 BUILD
                            M3 VERT BUILD
                            • Stan
                              • Jul 2019
                              • 774
                              #104
                              • 968Reckless
                                • May 2013
                                • 1095
                                #105
                                oh gotcha, i wouldn't have any room for that. thanks though
                                /// MTech Belts ///
                                S52 BUILD
                                M3 VERT BUILD
