E30 M3 Vert
  • 968Reckless
    • May 2013
    • 1095
    #121
    Originally posted by Cptcarisma
    El Bumpo for an Update.
    will this car be on the road in the Spring?
    CAPP
    Unfortunately not, I've been slacking on this build but hopefully the motor will be in this weekend. The 2002 will be road ready this spring though.
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
    • 968Reckless
      • May 2013
      • 1095
      #122
      Minor update. Went to install the trans but the clutch alignment tool didn't feel as snug as it should have. From my research the e46 and e36 both use the same size pilot bearing (15x32x10) so the zf320 should fit. Has anyone run into needing to swap to the e30 pilot bearing (12x32x10)?
      Click image for larger version  Name:	51954937453_e64c79fe5f_z.jpg Views:	0 Size:	93.5 KB ID:	10050513
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • Staszek
        • 2533
        #123
        Looking good!!!
        • Northern
          I like cupcakes & sh!tboxes
          • 5265
          #124
          You're right, pilot bearing matches the trans, but you could've been supplied the wrong alignment tool
          Originally posted by priapism
          Originally posted by shameson
          • Cptcarisma
            • Jan 2011
            • 466
            #125
            Bump for this.. Did this build ever reach the finish line?
            CAPP
            • Mike36
              • 1079
              #126
              Originally posted by 968Reckless
              Click image for larger version Name:	51553835357_c0e362bcbc_z.jpg Views:	0 Size:	80.1 KB ID:	10033241
              Have you considered adding the weather strip between the bumper and kidney grills?
