Nonsense Thread
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    #6121
    Originally posted by agent
    I havent loled that hard in a minute
    My mini cooper goes through oil like a mother fucker (consumption) as well as my brothers. Both are NA r56s with the N14.
    I always tell my bro to check the oil in his car, but he never does, so when he comes in for an oil change, about 2.5 QTs come out.
    • flyboyx
      • 8371
      #6122
      ^ second that. My truck was a half gallon low on oil but has never leaked. Now I check it once a week. Not leaking anything on the ground so it cant be too severe of a leak
      yeah, but your truck holds a quart shy 4 gallons of oil. mine has a slow leak somewhere in the top rear of the engine by the turbo. I have been meaning to fix it for years. I get about a silver dollar sized oil spot on the concrete wherever I park it.
      I do check the oil in all my cars every time I fill up the tank though. its an easy chore to accomplish while you are standing there anyway.
      Gigitty Gigitty!!!!
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #6123
        Yep. Real trucks take gallons of oil lol.
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • mrsleeve
          • Mar 2005
          • 16390
          #6124
          So an fzj80 is classed as a real truck then, they hold just shy of 2 gallons, since almost all 1fzs leak most of us just fill with 8 quarts anyway
          Originally posted by Fusion
          William Pitt-
          • HennaE30
            • Apr 2014
            • 1965
            #6125
            I picked up a wrecked 89 325is off a friend a few weeks ago for almost nothing. He hydroplaned into a guard rail due to bald tires. The hinge pillar is caved in slightly and door mounts are bent.
            Do you guys think this is salvageable?
            how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
            Originally posted by Northern
            beer is my new liver cleanse.
            Henna - '84 Hennarot 325e
            Lola - '89 Schwarz 325is - being saved
            Christine - '88 Schwarz 325is - Spec E30 Racecar
            '01 White F150 Lariat 4x4 Supercrew - Daily
            Dad's '05 Interlagosblau M3
            • rturbo 930
              • Dec 2005
              • 2629
              #6126
              I would think a good shop could fix that. I'm thinking you'd replace the rocker, and you could pull the rest into shape with some effort.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #6127
                Yes only problem is that every panel there is NLA so you’d have to find a donor or make your own if you can salvage the panels
                • rturbo 930
                  • Dec 2005
                  • 2629
                  #6128
                  I thought the rocker was still available? Some guy had a thread about this just a week ago, sounded like the rocker was still available from BMW.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #6129
                    Not unless they brought it back. When I did my rocker panels they were NLA and I had to buy a repro off of fixmyrust.com fit and finish is pretty good but its not an original panel. Its made by a company in Denmark.
                    • Mediumrarechicken
                      • May 2017
                      • 759
                      #6130
                      Metal is metal, if it's not exact hammer on it.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #6131
                        That wasn’t exactly the case yes it needed tweeked a little but the problem with the the aftermarket one was the metal was a little thinner and it was missing a seam on it. If you notice on the cars that havent had rocker work just behind the A pillar there is a seam in the rocker panel where it meets the other panels. It was missing the notch on the panel to make that seam so you just have a flush and smooth panel. Not a big deal cause you’ll likely never notice it but still makes it not exact.
                        • HennaE30
                          • Apr 2014
                          • 1965
                          #6132
                          I also have a set of brand new iS rockers to go on it once it’s finished, as well as a rolling chassis we are going to strip soon if we need to splice the bodies.
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5284
                            #6133
                            the rest of the car looks good, I'd go for the rocker repair and beat on the A pillar a bit, assuming it needs a little tweaking.
                            Should be easy to tell with a new door.
                            Originally posted by priapism
                            Originally posted by shameson
                            • HennaE30
                              • Apr 2014
                              • 1965
                              #6134
                              Was going to take it around to get a couple quotes on getting it fixed. Considering how little I paid for it, I’m okay with spending some money to get it fixed right.
                              • E30 Wagen
                                • Jul 2005
                                • 3434
                                #6135
                                I was looking for the driver's hinge column a few years ago but it was nla, not sure if the passenger side is. Looks like maybe ECS can get it? https://www.ecstuning.com/b-genuine-...r/41211959004/
                                I'd go for the replacement instead of trying to bend it back. If you can't buy it new I'd hunt down a donor car to simply cut out that whole section including the rocker panel.
                                My Feedback
