Nonsense Thread
  • mrsleeve
    • Mar 2005
    • 16390
    #13681
    Originally posted by 2mAn
    Roses?
    Shit I thought I multi quoted that last.
    YES Roses
    Untitled by mrsleeve, on Flickr
    Originally posted by Fusion
    William Pitt-
    • 2mAn
      Señior Mod
      • 21085
      #13682
      YES Roses
      Thats dope. PM me details if you still make em
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        #13683
        That's so cool!
        Def stealing that idea
        • MR E30 325is
          • Dec 2008
          • 3300
          #13684
          That is really cool Sleeve!
          On V-Day I officially started dating this girl I have been spending time with for the past few months. Didn't get her any gifts, other than some time together, if you know what I mean.
          My previous build (currently E30-less)
          http://www.r3vlimited.com/board/showthread.php?t=170390
          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
          • 2mAn
            Señior Mod
            • 21085
            #13685
            So back to work after a long weekend. Celebrated my daughters 1st birthday which was fun. Failed at welding up the Alfas inner panel on my second attempt and .... had a fun run with the i3. Now Im back to work where I have an idiot co-worker who is really bad at updating his notes and causes chaos for everyone around him, especially me.
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5616
              #13686
              What's going on w the welding?
              • 2mAn
                Señior Mod
                • 21085
                #13687
                Long story... rookie mistakes Im sure. Im prepping for my 3rd attempt. Talking to a few Alfa guys right now to see if what I think Im doing wrong is what is actually preventing it from properly welding the two panels. Basically I dont have a spot welder so Im trying to weld through small drilled holes to mimic spot welds
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5616
                  #13688
                  pics
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5284
                    #13689
                    How small of a hole are we talking?
                    Best luck I've had is with 3/16-1/4" holes and started the weld from the center and worked my way out to the outer layer
                    Originally posted by priapism
                    Originally posted by shameson
                    • 2mAn
                      Señior Mod
                      • 21085
                      #13690
                      It appears there will be a great solution coming soon. Basically someone with proper welding experience will push me aside and show me how its done lol
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5616
                        #13691
                        that's no fun
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          #13692
                          That is no fun. You could be pop rivet guy 2.0.
                          • 2mAn
                            Señior Mod
                            • 21085
                            #13693
                            no no no...
                            EDIT: Looks like I'm on my own... all good.
                            So there are no pics, maybe I will take some tonight, but here's the long version of what's going on and the panel Im trying to weld in:
                            Its a series of mistakes that I'm making as a novice welder. I might have ironed them all out for my 3rd attempt, but its quite frustrating and my confidence that it will work has shrunk with each failed attempt. The replacement panel itself has accepted the welding just fine, which has been a pain to grind and redrill, but its my low confidence that's been the big problem. I keep thinking I'm prepped and it will work, but then it doesn't.
                            1st attempt there was a lot of bare metal and I painted everything with a Rust Reformer to protect any bare metal from rusting going forward. Then I painted a weld-thru primer over the spots of the body that were getting welded. My brain didn't think about the fact that the first layer of paint was going to stop any welding to properly work... fail
                            2nd attempt took those areas that were to to be welded back down to bare metal and only using weld thru primer on them, but it still didn't take. Then to make matters worse, the horizontal section had too much of a gap that I clamped down and figured the weld would hold it together and again nothing. fail...
                            At this point I think the panel is ready to accept the weld, but I'm thinking on this 3rd attempt I'm going to just leave it as bare metal, but I also think I will change my grounding point. I've been using the new panel as the grounding and am also trying to weld thru the new panel to the car, but my thinking is that the welding path doesn't feel that the car itself is part of the process and just merely a bystander. So in addition to bare metal, the plan is to use the body as the grounding point so the weld must pass through the new panel and weld to the body. Also going to be much more aware of the gap on the horizontal panel. That one sucks too because I'm laying down trying to weld up, going against gravity,
                            Hope that clears up my struggle. It sucks that I'm in LA and do this completely solo as I feel there is a huge amount of people who could quickly have come and smacked me upside my head for making my rookie mistakes
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • twright
                              • 707
                              #13694
                              I'm sure there are people like that. The only problem is that they want to be paid fair wages for that knowledge and that prices me out of the market.
                              Stay at it. You'll figure it out.
                              "It sucks that I'm in LA and do this completely solo as I feel there is a huge amount of people who could quickly have come and smacked me upside my head for making my rookie mistakes["
                              • 2mAn
                                Señior Mod
                                • 21085
                                #13695
                                There is a small pool of people willing to do rust repair on an old Alfa and those that do will hold the car hostage for months. There is plenty of people who are good at welding and can chime in to help a DIY guy
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
