E30 325iX turbo with 1018hp / 1016Nm @ 2,3bar
  • mw044
    • Dec 2008
    • 59
    Dynoaction, burnout and 0-190km/h:
    Still missing ~100hp. To be continued..
    Edit. Specs (OLD SPECS, will update at somepoint)
    Engine:
    -original m20b25
    -m54b30 pistons (compheight modified slightly)
    -m50 non vanos conrods
    -m21 diesel 81mm crank
    -enem z45 turbo camshaft
    -ported head
    -"o-ringed" block with stock headgasket
    -holset hx52 mfs with #16 exhaust housing
    -custom exhaust manifold
    -600x300x76 intercooler
    -4,5/3,5" exhaust system
    -s38b36 flywheel with 240mm sintered disc & sachs race -765
    -megasquirt + msd 6al
    -630cc siemens deka
    -2x walbro 255LPH with 1,5L catch tank
    -PLX wideband lambda
    -594hp/794nm @ 2bar
    front axle:
    -height adjustable (135kg) springs with spax adjustable shocks.
    -camber adjustable topmounts with uniball
    -e87 1-series rear hubs in front
    -330i/d discs (325x25) (with 5mm spacer)
    -e32 735i calipers
    -POM control arm bushings
    rear axle:
    -e30 m3 gr.N rear springs (180kg) with spax adjustable shocks
    -camber/toe adjustable subframe
    -e36 compact rear hubs
    -e34 m5 discs (300x20) and calipers
    -POM bushings @ subframe + diff, powerflex @ trailing arms
    -clutch type 25% LSD diff 3.91:1
    Drivetrain:
    -stock 260 getrag
    -stock transfer case
    -7mm spacer in front of front driveshaft
    -reinforced front diff 3.91:1
    -stock halfshafts
  • agile30
    • 832
    HOLY FUCKING iX!!!!!. POOR parking lot
    Originally posted by Good & Tight
    It takes real man to mount a big woman, all you haters are just scared boys.
    • alexw
      • 1140
      Do want.
      alexw
      (2) E30 tourings - sold, E30 M3 - sold, 89 325ix sedan, 91 318is slicktop
      Wisconsin Members!- Join WiBimmers.com, Wisconsin's BMW community.
      • F34R
        sLaughter
        • 12376
        Awesome find!
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
          • 34844
          Originally posted by E30 F34R
          Awesome find!
          it's his car...
          still want to know about your front diff reinforcements! :)
          • F34R
            sLaughter
            • 12376
            Originally posted by nando
            it's his car...
            It looked like he was just posting specs, that is awesome. 1+ on specs sense you own it.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
            • ten2doyle102
              • 306
              it's his car...
              This and what else did you have to do to the drivetrain to get it to handle the power like that?
              1991 318is - Icy, the ice racing e30
              Now offering Custom Rally Light bars Click the link below for more information!
              http://www.r3vlimited.com/board/showthread.php?t=342498
              • dannyyisntt
                • 3141
                Hot damn
                  • 34844
                  AFAIK the only thing he has is a reinforced front diff, those little spider gears are tiny like to die in drag racing. Everyone has wierd ideas about transfercases exploding but that's pretty rare, they're pretty stout. Maybe welded/lengthened front DS?
                  • mw044
                    • Dec 2008
                    • 59
                    Exactly. I've so far blown 4 front diffs. Everytime those little spider gears explode into million pieces. Now I have reinforced unit. Otherwise drivetrain is pretty much original.
                    • Rocla
                      • 922
                      Any chances to drive quatermile this summer?
                      Current:
                      BMW 320i 2d 2.0 m20 -88
                      BMW 325i Cabriolet 2.5 m50 -88
                      BMW 316i touring 1.6 m40 -90
                      BMW 320i 4d 2,2 m54 -01
                      • mw044
                        • Dec 2008
                        • 59
                        If they can arrange some event in Kalajoki.. rumors tell that there would be one 28.8, but not sure yet.
                        • Rocla
                          • 922
                          10's or sub 10's ?
                          Current:
                          • StereoInstaller1
                            GAS
                            • 22679
                            Holy Mother of God.
                            I just can't imagine how much fun it would be to destroy the Evo-n-STi crowd.
                            Even a quick 4 wheel burnout at a stoplight next to an Evo would be damn near worth the price of admission...and the ticket!
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • Mlarsen
                              • 4082
                              So much inspiration for a fellow iX driver, absolutely awesome! By reinforcing, what did you have to do?
