Looking for E30 owners Reviews for Bimmerworld rear sway bar
  • OSAH racing
    • Apr 2022
    • 244
    Bimmerworld has a rear sway bar that allows more trave of the trailing arm. I am wondering who has one and if they are getting more control that the regular rear sway bar?
    Link to the bar from Bimmerworld: https://www.bimmerworld.com/E30-M3-F...Package_4.html
  • moatilliatta
    • 6152
    I find these cars like a smaller rear bar, something like a IE or AAF 16MM..
    @Zakspeed_US
    • OSAH racing
      • Apr 2022
      • 244
      Thank you
      • E30SPDFRK
        • 5712
        I don't understand how a kink in the lever arm would gain more travel, sounds like marketing to me.
        Byron
        Leichtbau
        • 88Sedan
          • Apr 2023
          • 263
          I'll be updating/refreshing my rear suspension this Spring as I finish the front right now. I am also looking for a 16mm adjustable rear sway bar.
          Something I'm curious about is buying a kit that uses a 'standard' style/size/shape polyurethane bushing for future replacement servicing. The AAF one looks like it uses a captured 2 piece press in bushing unlike most.
          I'm leaning towards the UUC or Whiteline kit at the moment. In the front I changed to m3 style endlinks mounted direct onto the strut, which I read makes the bar act stiffer.
          • Digitalwave
            is a poseur
            • 6299
            I found 19mm way too large. I settled on the 16mm because it was the smallest aftermarket I could find. Would have probably run 14mm or 15mm if I could an adjustable one that worked with adjustable end links.
            RISING EDGE
            • OSAH racing
              • Apr 2022
              • 244
              Thanks, your advice on this counts a lot
              • 88Sedan
                • Apr 2023
                • 263
                Which one did you get? And if you've pushed the car hard in turns, is it pretty balanced or does it easily oversteer?
                • Digitalwave
                  is a poseur
                  • 6299
                  Eibach
                  The rear sway bar is one piece of a much larger puzzle, so I don't think I can answer the second part of that for you.
                  RISING EDGE
                  • 88Sedan
                    • Apr 2023
                    • 263
                    Eibach
                    Yes I know that for sure. I was just curious how your current setup acts at the limit. I wasn't asking how my car would perform with the same sway bar.
                    My friends car with a big rear sway bar on its softest setting makes the car really prone to oversteer and we have similar spring rates including F:R ratio (both H&R).
                    I actually havent rebuilt my rear end yet which will start very soon. I'm going to hold off purchasing a rear bar until I see how the complete car works together afterwards.
