Shifter Setup
  • JGood
    • Jan 2004
    • 7959
    #61
    Originally posted by lifeiskaos
    It took about 10 minutes with an angle grinder and some careful drilling. I didn't think a writeup was necessary, but hopefully one of the other guys will do one :D
    Yeah, there appears to be nothing to it. I was just going to take some before and after measurements of throw and shifter height.
    I was considering using some rubber washers of some sort between the body and shift console to help eliminate some of the vibrations, as my car vibrates pretty bad as it is with the 75D bushings all around.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Paukert11
      • Nov 2008
      • 1295
      #62
      im rocking a e36 short shift, r-mracing.com sells them
      • Ian F
        • 148
        #63
        Originally posted by Bishop
        I kinda started to get the feel the 1.9 is the best compromise, and to just replace all the bushings... I haven't made a decision yet though.
        This is exactly what I'll be doing for my recently purchased '88 325is. I'm pretty sure most of my shifter's problems are due to toasted bushings... but also bought the 1.9 lever since it's relatively inexpensive and the whole thing will be apart anyway. We have two MINI's with SSK's that I dislike quite a bit, so 'notchiness' is to be avoided. I also know I don't want the shift knob to be much - if any - lower than stock.
        '88 325is: Diamond Schwartz; 210K miles; Koni SA; H&R springs; poly bushings (sold)
        '03 TDi Wagon; 5 spd (Ho-hum DD; 326K miles and counting...)
        '64 Morris Mini Cooper (w/e vintage toy #1)
        '72 Triumph GT6 (w/e vintage toy #2)
        '73 Volvo 1800ES (future vintage restomod project)
        • Ian F
          • 148
          #64
          Well... as I stare at the underside of my car... I can see this is going to be one hell of an annoying project... :(
          FWIW, the how-to on Pelican makes it look like there's waaaay more room to work than there really is... :roll:
          • 36brua
            • 689
            #65
            Quick question...
            What bushing/shifter cup is used when installing the Z3 /current lever in the metal console retrofit ?
            I copied a post about using 2-3 ? new ball cup/bearings and resizing thickness of one as a spacer ? and using the stk circlip, but of course I've no idea where that info was posted thanks
            My CA legal M60 swap
            The happening in our garage
            • Bishop
              • 4913
              #66
              Wish I could help, this whole plan hasn't come to fruition yet... I've been buying up guns and gun related things instead and just making repairs on the car from my last track day.
              PM me for detailing services in the Longmont / Boulder Area in Colorado!
              Originally posted by DTM190
              "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
              • F34R
                sLaughter
                • 12376
                #67
                z4 shifter, UUC bushing replacements, MOMO knob, I love the setup. It is very spot on and quicker.
                My brother is rocking the z3 with stock bushing replacements. I think the z3 is a perfect DD app.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • Fusion
                  • Nov 2009
                  • 3659
                  #68
                  Could you guys recommend a lever for me? M50 with the IS gearbox.
                  My only problem is that 5th gear seems really "far away" and I'm insecure of revving 4th high and accidentally throwing 3rd in. For 5th I use the "push away" technique where I'm not holding the shifter, but pushing it out and forward with my palm in an angle.
                  Thank for any advice.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    #69
                    I like my z4 3.0 shifter. It took a little bit to learn the feel of the new setup and let everything loosen up but the more I use it the better it feels.
                    It is quite short though and it takes a fair bit more effort to find second. Haven't tracked it this way yet so we'll have to wait and see.
                    '89 Alpine S52 with goodies
                    • bataangpinoy
                      • Jul 2008
                      • 1636
                      #70
                      i've been thinking of trying the cosmo racing shifter extension because i cant seem to find a shifter that sits as high as the oem one does, and i like that height on my track car.
                      My feedback:
                      http://www.r3vlimited.com/board/showthread.php?t=186328
                      http://e30tech.com/forum/showthread.php?t=74911
                      Instagram:
                      @gears_n_glory
                      @functionmotorsports
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        #71
                        try jaffster knob sold at BW..or go for an X5 lever.
                        • rpob5t
                          • Aug 2007
                          • 162
                          #72
                          I'm using a B&M, have had it in the car for a few years now and have yet to break it so I guess that's a good sign. To be honest the shifter helped (throw lenght isn't a huge deal to me as long as its accurate/precise) but the UUC DSSR made the bigest change in feel; it really took all the excess slop out of the shifter...
                          Greg 1987 325is (fairly far from stock at this point)
