Let's try and guess a 1/4 time - round two
  • Jean
    • 18228
    Ok, so my first attempt was on street tires with crappy shocks, best result was
    Reaction 0.220
    E.T. 14.748
    MPH 97.275
    60ft 2.210
    2500lbs with b35swap/g260.6, and 3.46 rear end. This time on 225/50/15 kumho v710 and re-valved bilstein sports in place of worn out shocks.
    Any guesses?
    23
    13.9 - 14.1
    21.74%
    5
    14.1 - 14.3
    30.43%
    7
    14.3 - 14.5
    30.43%
    7
    14.5 - 14.7
    8.70%
    2
    14.7 - 14.9
    8.70%
    2
    The poll is expired.
  • Need4Speed1299
    • Oct 2007
    • 119
    14.2! Edit!
    • Wh33lhop
      • 11705
      paint sucks
      • Danny
        • 14216
        13.8@102
        • Dj Buttchug
          • Jun 2010
          • 7686
          dude cmon... thats a 10 second car lol
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • QBANG
            • Dec 2009
            • 160
            With that rear end you will have to shift to 4th before the light I assume. So I'll say 14@101.
            E30 M30B34 Mounts Available
            Email jharb79@gmail.com
            • dkbmxer002
              • Nov 2007
              • 1389
              stiffer shocks might hurt you, reaction time does NOT affect your e/t or trap and your mph should be good for 13's.
              my guess is 14.4 at 96-98 depending on what your old tires were. i'm guessing your 60 foot was around 2.2 2.3 maybe?
              lower your tires to about 20-24 psi at most.
              • JGood
                • Jan 2004
                • 7959
                14.1 @ 98
                I've done the 1/4 with v710's a few times, my trap speed was 1-2 mph higher with street tires, but the ET was lower with the v710's. That was in my m50 car.
                I was 14.4@94 with my m50, now I have s50 cams and am hoping for the exact time/speed I estimated yours at.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • M-technik-3
                  • 18946
                  Did mine eons ago with 3.73 with getrag 250 m50 on Kumho v710 and car ran 14.1 at 97. Tires were not meant for drag racing. Too hard and they tend to just wheel hop. Set of soft sidewalls would be better.
                  Going with 14.1 and maybe 96-98
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    same 14.7
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1991 318IS slick top
                    1997 M3 sedan
                    2001 325CI DD
                    “whoever turns the wheel the least, wins"
                      • 34844
                      I'd guess mid 14s
                      it takes a lot to wack almost a full second off your time..
                      • dkbmxer002
                        • Nov 2007
                        • 1389
                        general rule of them is also spinning equals higher mph and hooking equals quicker e/t
                        • e30s50dan
                          • Nov 2008
                          • 2076
                          WELL !!!!!!!!!!!!!!!!!!!!! what is it
                          NASA
                          BMWCCA member
                          PCA member 25yrs
                          1997 M3 sedan
                          2001 325CI DD
                          • ed94r
                            • Mar 2004
                            • 382
                            14.6@97 with a 2.1 60ft.
                            At the same track with the same power as last time or bet's off. $5 paypal if you go over 99mph.
                            Tires: I don't care what you put on there you won't go sub 2.0.
                            This time I will take the tweeter panels.
                            Ed
                            1988 E30/S50...now with S52; Track
                            1994 Miata R; ES Solo2
                            1998 Lexus LX470; Wife (Slee'd anyway)
                            2002 BMW 530i; A+ Commuter
                            2002 BMW 325iT; Sport/Premium 5-speed
                            2011 21' EconoTrailer
                            • Kershaw
                              • 11822
                              if you dont pull a 2.00 flat 60' time with v710s i'll be disappointed. slow down. focus on your launch. dont worry about the light. it doesnt matter if it takes you a second to launch. make sure you launch that car perfectly.
                              you should be able to hit low 14s pretty easily. i voted 13.9-14.1.
                              first run out, drop the clutch at 6k rpm and let the v710s hook up. see how that works out for you. then work from there.
                              AWD > RWD
