I want to change the angle of my steering wheel
  • Lof8
    • Oct 2006
    • 2827
    Yes, you can pull them off after you drill the bolt heads off. There is a piece of flat bar connecting the two nuts. The nuts are welded to the flat bar and the whole assembly is removable. Pretty convenient, actually.
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
    • irish44j
      • 2763
      excellent, thanks.
      Stage rally/rallycross e30 build/competition journal
      Track/street e21 build
      visit Condor Speed Shop
      visit Motorsport Hardware
      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
      • george graves
        • 20003
        It's been a while since I've looked ay my steering coulmn, but is there a way you could bring it towards you about an inch? I'm 6'1 or 6'2" - and I need it closer - just about an inch or an inch and a half with a mtech2 wheel.
        Originally posted by Matt-B
        • Lof8
          • Oct 2006
          • 2827
          I just ordered a 1/2" momo wheel spacer. I didnt see any easy options for extending the steering column itself.
          S50'd
          • j0oftheworld
            • 480
            Those "dished" Rally style wheels (momo mod7 etc) extend towards the drive 60mm..
            • djjerme
              • 5082
              spacer and quick release. That should get you there.. I am 6'1" and had the same problem, installed an NRG quick release, and it bumped the wheel out about an inch, it's much better!
              2016 Ford Flex
              • SLEEPYDUB
                • 658
                I did this yesterday. It took me 5 hours of off and on work to get the stupid bolts out.
                Heres some suggestions to anyone trying this.
                1) Get a GOOD drill bit and drill a hole as deep as you can into the bolt. Then use a screw extractor to turn it out. Works very easy if the hole is deep enough.
                2) If you fuck that up, just use a dremel and cut the head of the bolt off. Notching it for a flat head screw driver just doesn't work very well. If you cut the head off, the back plate just comes right out, then you can use a vice grip to turn the bolt out and reuse the back plate.
                Hope everyone has an easier time with this than I did. And I really hope it was worth all my trouble, I think it is though.
                - AXIS POWERS - 2JZ E30 Build
                Current Project - 87 325is 2JZ Swapped with M4 DCT
                • george graves
                  • 20003
                  Thanks. But I don't want to give up my mt2 wheel.
                  • irish44j
                    • 2763
                    damn....5 hours??
                    I'm screwed since I already tried to notch it and use a big screwdriver. now it's damn near impossible to get a drill bit to bite flush. I'll ahve to cut it off eventually, but shelved this project for a while, before getting too frustrated at somethign so simple being such a PITA (and frustrated at why BMW decided to not use freakin regular bolts, lol)
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5284
                      Anything that would stop you from drilling a hole in the anti-tamper bolts and using an easy out to get them out? Sounds easier than using a dremel to cut a screwdriver slot.
                      EDIT: aaaand answer right above... that's what I get for skipping page 2.
                      Originally posted by priapism
                      Originally posted by shameson
                      • TobyB
                        • 5297
                        I did it a different way-
                        undo the tamper bolts on the body, then make a strap of 1/4" steel with 2 8mm holes spaced
                        1" apart. Then put them in such that the wheel gets moved in towards
                        the center of the car a bit (yup, 1/4")
                        That worked, too.
                        t
                        • dogsbark26
                          • Nov 2008
                          • 533
                          So nobody has looked at putting a tilt wheel from another vehicle into an e30 hum?
                          • bmnut2002
                            • Nov 2009
                            • 198
                            Originally posted by irish44j
                            damn....5 hours??
                            Go to Harbor Freight and get a $15 4 inch electric grinder and cut a notch in the bolt head. The big cut off wheel make it easy to get up and on the bolt head. Also buy a cheap impact driver if you don't have one(the type you hit with a hammer) and use a flat blade screwdriver impact bit. Hit with hammer and the bolts will come loose. This whole process should take 10 to 20 minutes. Use two longer bolts and use whatever you want for spacers. Two large nuts per side works great as spacers. Install bolts. Done. Easy project.
                            Don't waste your time with drilling it out, you"ll be at it all day.
                            Kevin Doyle
                            KD Motorsports
                            KD.Motorsports@yahoo.com
                            9175 Willows Rd NE
                            Redmond, WA 98052
                            (425)556-9076
                            • e30_neverstock
                              • Nov 2011
                              • 283
                              this ^
                              • steinbachphoto
                                • Aug 2007
                                • 914
                                I don't see a point in that, once you find the angle that suits you there's no point in needing to change it.
                                http://www.steinbachphoto.ca
