stock fuel tank capacity per side?
  • NickiX
    • Jul 2011
    • 184
    Hey I was hoping somebody involved in track cars may have the answer I'm looking for. I need to figure out the capacity of the pre-88 fuel tank from the left side to the right side. Mainly if the left side of the tank was removed would there be a large amount of capacity lost? If so would be modifying a post-88 tank give a greater capacity in just the right side of the tank. Thanks
    89 325iX - stock but overflowing with factory extras
    85 324tdt -frankentrimmer
  • Kershaw
    • 11822
    it isnt a separate tank...
    AWD > RWD
    • rwh11385
      lance_entities
      • 18403
      But if you add a smuggler's compartment behind the driver's seat by cutting and welding the gas tank in half, you can put your weed in there.
      • NickiX
        • Jul 2011
        • 184
        I know its not a seperate tank. I was just wondering if someone had ever heard of or measured the capacity of the right hump of the tank to the left hump of the tank.
        • E30darkknight
          • Sep 2009
          • 422
          the whole tank holds 15 gallons, so most likely each side is gonna be half of that. so each side is approx ~7.5 gallons.
          • NickiX
            • Jul 2011
            • 184
            haha clever but thats not my plan
            • NickiX
              • Jul 2011
              • 184
              well I see the logic in that but the right side of the tank is a bit larger then the left side of the tank so I'm pretty sure there's a big difference in capacity per side but I don't know the exact number.
                • 34847
                it's 63 liters, not 15 gallons.
                • djjerme
                  • 5082
                  there was one year/model that had a single side tank (might have been an early 318 car..)
                  2016 Ford Flex
                    My guess, and it is only that, is that the right side of either tank holds about 8 gallons if the tank were to be severed at the top of the saddle over the drive shaft.
                    • NickiX
                      • Jul 2011
                      • 184
                      Hmm that would be perfect. I cant find anything in etk though. Euro 316 maybe?
                      • NickiX
                        • Jul 2011
                        • 184
                        Yeah that was close to my guess also.
                        • djjerme
                          • 5082
                          Here's a pic from RealOEM.
                          http://www.realoem.com/bmw/showparts...49&hg=16&fg=05
                          It's actually an aux tank that is 10L.. I am not sure the exact models but the Euro M3 has em, as well the Alpina's.
                          2016 Ford Flex
                          • Jaxx_
                            • Dec 2009
                            • 1880
                            my 318 is a single side tank, on the passenger's side. it's supposed to be ~12gal, and I've never put more than 10 gallons in it.
                            • Invisible Saddle
                              • Jun 2008
                              • 88
                              were you thinking of doing a pre-lift setup on the tank?? to pull more full over to the right tank?? spec e30 really was involved in a thread regarding that subject of the fuel tank.
