Wisefab Lock Kit for race applications?
  • Mylch
    • 390
    You can get the road/race kit from SLR which does not include his arms I think.
    Drifter??? High Quality Rack Spacers.
    • Wanganstyle
      • 2828
      Originally posted by Massimo
      It will be mostly hillclimbs time attacks. It is more a comfort thing then a function change. Obviously I can do with our it but would be nice not having to cross hands over to make sharp turns. Just wanted to see if anyone sore any disadvantages in it.
      Yes it was designed for drift but dose not mean it can not be used for racing.
      Wisefab kit was designed with one of my clients in europe for full professional drifting. There was no intention of having a front sway bar in the initial design; however anything can be adapted.
      Realistically if the desire is to have a Hillclimb car; more steering angle is not really needed; massive power and AERO is. huge steering angle is DRIFT stuff; if you are drifting while attempting to hillclimb then something is wrong with the footwork setup (or the driver just really wishes he was a drifter)
      if going for more angle from a Stock BMW rack a Z4 rack (unpowered), or z4m rack (powered) or e46m rack would hit both targets of MORE ANGLE and QUICKER RATIO.
      • 10Toes
        Me Father Was A Tree
        • Jan 2008
        • 61222
        Originally posted by E30SPDFRK
        First of all, the wisefab kit doesn't effect steering ratio at all. All it changes is the angle the wheels move from turning the steering wheel the same amount.
        Wut That is the steering ratio, and it is changed... You turn the steering wheel this much ___ and the wheel turns this much __.
        It does change it, but I does look like all these kits are more designed for drifting not real racing.
        All the OP really needs is something like the end piece that connects to the strut housing and changes the pivot location and or the tie rod location closer together.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          ^ this.
          Originally posted by 10Toes
          Looks like there is a hole for the sway bar, and if not it is not hard to drill one.
          The link specifically states there is no provision for an endlink/swaybar, and I'm typically against arbitrarily drilling holes in critical suspension components. But as wangan said, you could definitely find a way.
          Originally posted by priapism
          Originally posted by shameson
          • Wanganstyle
            • 2828
            Originally posted by Northern
            ^ this.
            M3 sway bar links attach between Strut housing and sway bar............
            • FLG
              • Sep 2011
              • 3165
              Haoming, geometry would be severely off if using the m3 setup for the sway bar with the wheels being so far out.
              Sent from my SCH-I545 using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • E30SPDFRK
                • 5716
                The OP was looking for 1 turn lock to lock. What I meant thaw hat I said was that if you have to turn 3 times lock to lock now, you will still need to turn 3 turns lock to lock with the wisefab kit. The ratio of wheel to steering wheel input will change, but you won't get less turns.
                Byron
                Leichtbau
                • Wanganstyle
                  • 2828
                  Of course ; as wise fab is designed suspension rates and motion to DELETE THE FRONT BAR.
                  Frankly the idea of using drift parts on a hill climb car is only interesting if the car is drifting up the hillclimb like the mad mike rx7 4 rotor animal
                  • acolella76
                    • 2950
                    I wonder if those SLR control arms are the same dimensions as OEM... they could be a relatively cheap way to correct roll center on non-M cars.
                    Also as far as getting a 1:1 ratio, look into steering ratio quickeners.
                    -Alex
                    • Northern
                      • 5284
                      Welcome to page 1 :p
                      ...even if you strut mounted something, the extra distance (horizontally) to the strut would cause issues with endlinks in fitment, life, and leverage on the swaybar.
                      I̶ ̶d̶o̶u̶b̶t̶ ̶t̶h̶e̶y̶ ̶m̶a̶t̶c̶h̶ ̶a̶n̶y̶t̶h̶i̶n̶g̶ ̶O̶E̶M̶ ̶c̶o̶n̶s̶i̶d̶e̶r̶i̶n̶g̶ ̶h̶o̶w̶ ̶t̶h̶e̶y̶ ̶m̶o̶u̶n̶t̶ ̶u̶p̶ ̶t̶o̶ ̶t̶h̶e̶ ̶k̶n̶u̶c̶k̶l̶e̶.̶ ̶
                      I take that back, I didn't look very closely at the SLR setup. definitely looks more promising than the wisefab, and if it doesn't add tons of camber( or if you can order them with shorter arms) then it may be a cheap bump steer/roll center correction setup.
                      • TobyB
                        • 5298
                        Amusingly, for road racing, I found that lots of camber (up to -5 degrees for racing radials) and
                        a ton of caster (10+ or more) lowered lap times consistently.
                        1 turn lock- to- lock would have turned me into the incredible Hulk. Or dead meat.
                        As it is, the stock E30 ratio is a bit too high for comfort (as in, it's like steering a bus)
                        However, the stock 2002 ratio works just fine, and it's not much higher than the E30.
                        So if we were allowed, I'd run a z3/z4/whatever rack that lowered the ratio a bit.
                        And call it good.
                        If we were allowed to modify the trailing arm geometry, however, i'd do that in a heartbeat.
                        But we're not.
                        t
                        • Massimo
                          • Jan 2008
                          • 3207
                          I think some are a bit confused with what I am trying to acheve here. I do not want more steering angle I simply want to be able to got 1 turn lock to lock with maybe slightly less steering angle then Stock.
                          I am not looking for made steering angle for mad drifto. I want to be able to keep my hand on the steering wheel the whole time with out having to cross my hands over. As I mentioned it is not a necessity more of a want.
                          The SLR kit dose look more fitted, to what I want. plus it is cheaper. It is just a thought for now as my car is years away from running again.
                          • !kid
                            • 1362
                            I don't know about the road race kit but I know the SLR drift kit has a possible 3 inches wider control arm at full adjustment over stock e30 arms.
                            :borg:
                            • E30SPDFRK
                              • 5716
                              If the only thing you want is a quicker ratio steering, mount a steering multiplier into your steering column.
                              Byron
                              Leichtbau
                              • IronFreak
                                • Dec 2012
                                • 3702
                                ^^^Problem solved
                                http://www.speedwaymotors.com/Speedw...ener,8280.html
                                With something like this on my 95 m3 rack I'd be roughly 1.5T lock to lock. get a z3 with a quickener and you'd be at around 1.35T LTL...........I might buy one of these hahaha
                                Instagram @rebellionforge
