E30 Aerodynamics
  • squidmaster
    • Aug 2011
    • 2666
    #166
    the 2.3 was the rally series, but couldn't outpace the quattro at all, so they changed direction and released the 2.5 with dtm specifically in mind. at least that's what I've read from those "history of the w201" articles.
    Honestly though, probably 95% of all this competition stuff is hearsay. Who knows what goes on behind the closed doors-- what the executives truly wanted to produce and why
    • TheDirtyS54Thirty
      • Dec 2016
      • 88
      #167
      I got a couple things brewing, more pics to follow once I finish the rear set up.
      E30 S54
      • 2mAn
        SeƱior Mod
        • 20583
        #168
        diffuser?
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • TheDirtyS54Thirty
          • Dec 2016
          • 88
          #169
          Originally posted by 2mAn
          diffuser?
          no nothing that crazy lol. I have to bolt in the chassis mounts for the wing and cut up trunk for the uprights to pass through.
          E30 S54
          • 2mAn
            SeƱior Mod
            • 20583
            #170
            Your cars the one that Matt Farah drove right?
            Have you taken it to any track days yet?
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • TheDirtyS54Thirty
              • Dec 2016
              • 88
              #171
              yup this is the one and yes Ive tracked it a bunch of times.
              E30 S54
              • 2mAn
                SeƱior Mod
                • 20583
                #172
                E30 Aerodynamics
                That's funny, I have a swapped E30 and a W204 also. Both your cars are crazier versions of my own
                Edit: back on track, are you tying the rear wing to the suspension or the trunk floor?
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                • TheDirtyS54Thirty
                  • Dec 2016
                  • 88
                  #173
                  but I just have the e30, I did have an e90 m3 that I just sold a couple weeks ago though. As for the wing its being bolted into the frame rails that pass through the trunk floor.
                  pictured are the chassis mounts
                  E30 S54
                  • 2mAn
                    SeƱior Mod
                    • 20583
                    #174
                    Nice that should be pretty damn functional.
                    I thought you had a C63, never mind. Too many people on those videos
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    • TheDirtyS54Thirty
                      • Dec 2016
                      • 88
                      #175
                      installed the 61" APR GT-250 wing finally with custom end plates.
                      E30 S54
                      • e30davie
                        • Apr 2016
                        • 1788
                        #176
                        If nothing else it looks very serious. Had a chance to test it out yet?
                        • TheDirtyS54Thirty
                          • Dec 2016
                          • 88
                          #177
                          Although not the greatest track to be testing the aero to its full potential, Ill be tracking this Saturday.
                          E30 S54
                          • RoccoB517
                            • Jul 2013
                            • 320
                            #178
                            So an interesting follow up from me here. I took my car to Road Atlanta with the new drivetrain and managed to exceed my previous top speed by quite a lot on the long back straight. This promptly broke the end off of my wing and tore the 1" fender washers clean through my 16 gauge aluminum flat bottom. Back to the drawing board on these items, but holy crap the force must have been massive to do those things.
                            sigpicLevel Motorsport: www.levelmotorsport.com
                            Instagram: https://www.instagram.com/levelmotorsport/
                            Facebook: https://www.facebook.com/LeVelIndustries/?fref=ts
                            • vpilarrt
                              • Jun 2006
                              • 2096
                              #179
                              When you weld metal the heat effected zone (which can be quite large on aluminum since it conducts heat so well) returns to as-forged strength. Assuming you used 2024 it would take 495 lbs of drag on the wing to tear out a 1" diameter x .0625" thick plug in the bottom of the support. I eyeballed your setup to have a 5:1 height (of wing above the bottom of the support) vs width (of the bottom of the support) which give a 500% mechanical advantage to the load due to drag.
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #180
                                Pictures?
                                Sent from my SM-G920T using Tapatalk
                                Shadetree30
