24V = smithereens after 50 hours of racing
  • nrubenstein
    • 3148
    Originally posted by Liquidity
    That's really your argument? Seriously? That logging your hours somehow makes your engine failure more relevant?
    Listen up everybody! Wangan logs his hours! He's the expert of all BMW racing now! All of the time you've been reliably racing your BMW engine, it doesn't matter anymore, Wangan is here to tell you your engine is unreliable!
    Well, S50s are known to drop valves, and S52s have terrible crank harmonics. They are both well known to be prone to blowing up on track.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • mooseheadm5
      • Apr 2009
      • 375
      Originally posted by kronus
      the vorshlag style through-bolt mount with poly sandwiched between metal cups is probably the best approach I've seen.
      So far...
      -P
      Moosehead Engineering
      • Wanganstyle
        • 2828
        Title of thread applies to actual racing cars; please don't spout r3vtarded data if you are not actually racing. i.e. your Suit, cage, HANS actually all passes tech.
        Street car + hpde does NOT = actually racing.
        everyone else seems to have no problem understanding the context of this post; solid mounts is = not good for your engine
        This was a M52b28; Dropped a valve (cracked retainer on #6 intake)
        We were hoping its more durable in regards to harmonics BUT solid mounts did not help it at all.
        • M-technik-3
          • 18946
          We run plain jane HD ones. Cheaper is better, hell we have run used ones. Cooked our last motor as well. Three races on it. Slapped together another 2.8 out spares that we cannibalized from previous engines. We expect to to get three races out of it.
          • e30_302
            • Sep 2013
            • 453
            $500 car my ass.
            • Liquidity
              • May 2014
              • 395
              No. The body of your post applies to you trying to form this thread into you becoming the be-all end-all of 24v reliability. If you want to share your experience, fine. But don't go preaching this like you've uncovered some truth and you must get the word out to the people before chaos strikes. You blew up a motor. Yeah, it sucks, but in the grand scheme of things - whoopty fucking do.
              • DesertBMW
                • Aug 2011
                • 1043
                Head was rebuilt stock; before it was swapped into our e30 racecar it had about 70k street miles attached to an automatic.
                we learned the hard way that valve spring retainers are not strong enough for over 7,000 rpm redline + endurance racing
                We can all totally disregard your posted failure results. Why? You took a 20 year old engine, and rebuilted it in indy shop, resurfaced the head, this increased the compression ratio higher, changed the dynamics of timing chain, valvetrain, then you increased the rev limit into red zone. Solid engine mounts plus that kind of RPM created some nasty harmonics inside the engine.
                Proper test would be brand new 24v from BMW factory with stock engine management and stock mounts, then do your racing.
                • Wanganstyle
                  • 2828
                  This is a race car; things are yes full raze.
                  have you ever read the Tis for a Bmw 24v engine?
                  Do you even know what detonation looks like? This engine has 0 detonation damage; I hope you have working eyeballs if you hold a drivers license.
                  Compression is easily adjusted with the proper Bmw head gasket; there is more than one thickness avail.
                  you probably have never asked at the bmw dealership.
                  M50 and m52 heads are designed to be resurfaced by bmw.
                  S52 is not; go read the Tis if you don't believe me
                  • camshaftgsxr
                    • Aug 2011
                    • 416
                    so, you rebuilt the head, did you refresh the bottom end? replace the oil pump? any kind of longevity maintenance?
                    not being accusatory, just playing devils advocate. can you say for certain that the engine was never mechanically overrun beyond its rpm limits?
                    BroWorks.com Bro is a lifestyle
                    • M-technik-3
                      • 18946
                      man who can piss the furtherest up the rope without it burning. too much whining going on in this thread.
                      it's lemons, i expect it to blow up or get destroyed now. It happens nearly every race for the team I'm on. My one guy will end up into the chevette no matter where it on the track. Three incidents with them it's like the cars are meant to be together.
                      • Wanganstyle
                        • 2828
                        IF going beyond stock 6,000 rev limit = over run then yes, it was ran with a turner motorsports chip to 7,000rpm for about 10 hours; I am 100% sure the raised rev limit contributed to the valve spring retainer failing.
                        We leaked down the short block cylinders individually before installing the built head; each cylinder was within 1.5% with MAC leak down tester.
                        It is easy to build a fixture to test for this; you can use it on each cylinder on head or block
                        Oil pumps on these engines rarely fail unless the nut backs off; ours was welded on.
                        The pickup falling apart due to vibration was something new to me
                        A dropped valve from broken retainer caused the carnage; it simply wore out.
                        All the bottom end bearings were still alive amazingly even with the destroyed oil pickup
                        lemons car = Looks like ASS, goes like stink
                        any good carnage photos ;) I love to look at aftermath of kabooms!
                        • M-technik-3
                          • 18946
                          I betcha he pissed his pants. That must have been the talk of the pits
                          • kronus
                            • Apr 2008
                            • 13032
                            i bet the rabbit pilot is real happy he doesn't have a face full of tire also
                            cars beep boop
                            • 2mAn
                              Señior Mod
                              • 21062
                              :rofl: how did that happen??
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • Wanganstyle
                                • 2828
                                somebody say yellow flag?
                                Oh, doh it was important! but the eyesore racing driver was very intensely concentrating on passing 10 cars on the inside turn 1 lol
                                the 24v e30 with full 22gal cell and loaded with coolsuit ice chest was only 2560lbs with 180lbs driver included. quite a party
                                kronos what does your truckasaurous weigh in at? id imagine less?
