24V = smithereens after 50 hours of racing
  • Wanganstyle
    • 2828
    I suggest those with delusions of grandeur regarding the strength of stock OEM BMW engines under heavy stress to review these photos.
    Stock longmotor saw 50 hours full racing before total dismay, 0 street miles in the e30. Head was rebuilt stock; before it was swapped into our e30 racecar it had about 70k street miles attached to an automatic.
    we learned the hard way that valve spring retainers are not strong enough for over 7,000 rpm redline + endurance racing
    Bottom and top were going to kaboom; top happened to pull the trigger first.
    failure happened at 2,000rpm idling on a lift; I was able to shut it down within a few seconds.
    head gasket was intact when broken down.
    Solid Billet motor mounts are brutal on the oil pickup regarding vibration stress.
    I would suggest a T-T s54 pan conversion for those with the budget; otherwise advance replacement of the pick up and oil pump every 30 hours
    Caged chassis + reinforced suspension and x members + solid mounts+ no rubber anywhere + full racing everything = destruction of engine via harmonics (eventually)
    destroyed oil pickup has little pieces of its casting alu in the suction screen.
    Valve head from #6, piston pin surround from #6, c clip for pin not pictured but intact (and floating in oil pan)
    Rod Bearings are not destroyed... - none were spun but did show slight starvation as our oil pump was destroyed internally.
  • kronus
    • Apr 2008
    • 13022
    that is so thoroughly and completely nuked
    you think the solid motor mounts contributed?
    cars beep boop
    • Wanganstyle
      • 2828
      I cant think of anything that nuked the oil pick up besides vibrations from billet mounts. Nothing touched it or came close to it; the pan was perfecto
      The pickup was bolted on solid and sealed to the oil pump; both 10mm screw/nut were tight
      this however was useless as the giant hole would feed our oil pump both metal AND Air!
      • Liquidity
        • May 2014
        • 395
        Wow. This one single failure has completely changed my mind about the reliability of BMW engines. I'm now gonna completely ignore the thousands of them that have been out there racing reliably for collective millions of miles. Thank you for this information!
        • nrubenstein
          • 3148
          Was anyone surprised by this?
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • mooseheadm5
            • Apr 2009
            • 375
            I don't know why people think that billet mounts are a good idea.
            -P
            Moosehead Engineering
            • Wanganstyle
              • 2828
              they are not; They were all we had avail to us for ($0 dollars locally)
              When you run lemons in a field of 200+ and risk another car re-shaping your front apron and radiator clearance............... you probably want those solid mounts
              how many millions of miles has yours been racing? Do you log the hours?
              I wasn't. Have seen M20 crankshafts broken in 2 places with rods still attached -
              • mooseheadm5
                • Apr 2009
                • 375
                So I guess I need to come up with a not solid but fail-safe mount. I've been thinking of this.
                -P
                • slammin.e28
                  שמע ישראל
                  • 12054
                  i don't know why people think that billet mounts are a good idea.
                  bcuz rcecr
                  • kronus
                    • Apr 2008
                    • 13022
                    the vorshlag style through-bolt mount with poly sandwiched between metal cups is probably the best approach I've seen.
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13022
                      bcuz rcecr
                      our lemon uses thick-wall square tube for motor mounts bcuz $0
                      cars beep boop
                      • Wanganstyle
                        • 2828
                        yes, it would be cheaper/easier than replacing oil pumps and broken apart pickups on a preemptive schedule
                        • G-Man the Visionary
                          • Apr 2013
                          • 543
                          Did someone say "mounts"?
                          Streetable poly mounts, trans mounts are here!
                          http://www.r3vlimited.com/board/show...ght=streetable
                          '94 318i
                          '07 335i
                          '11 X5
                          '89 325ic m30b35
                          • 2mAn
                            SeƱior Mod
                            • 20286
                            S52?
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                            -2006 Volkswagen Jetta TDI
                            Make R3V Great Again -2020
                            • Liquidity
                              • May 2014
                              • 395
                              That's really your argument? Seriously? That logging your hours somehow makes your engine failure more relevant?
                              Listen up everybody! Wangan logs his hours! He's the expert of all BMW racing now! All of the time you've been reliably racing your BMW engine, it doesn't matter anymore, Wangan is here to tell you your engine is unreliable!
