19mm Master Cylinder Options
  • e30mclow
    • Jun 2010
    • 202
    For those that have deleted their brake booster/servo, what master cylinder are you running?
    The preferred setup appears to be a 19/19mm master cylinder with the brake proportioning valve removed.
    I have a 19/20mm one from an early 316 (drum rears), but would prefer to start with a 19/19mm as people have reported success.
    VW Beetle 19mm? - Bolt pattern looks OK, but is a 4 port.
    Tilton 19mm - mounting point are in the 6 & 12 location rather than 3 & 9.
    Before anyone asks: My engine swap doesn't allow adequate room for a relocated/smaller servo (intake plenum & 3" IC piping are in the way).
  • e30mclow
    • Jun 2010
    • 202
    Pasting this old thread here in case someone else's search brought them here.
    Looks like old VW is the way to go. I'll post part numbers once I have the plan in place.
    • varg
      Florida Turbo Man
      • May 2014
      • 3429
      This might help https://www.bimmerforums.com/forum/s...r-Delete/page3
      IG @turbovarg
      '91 318is, M20 turbo
      • e30mclow
        • Jun 2010
        • 202
        Originally posted by varg
        Thanks, a lot of great info there!
        • TobyB
          • 5293
          The slightly bigger rear m/c piston is nice, because then you
          can run a limiting valve and actually use the rear brakes.
          A 1:1 master puts more than 70% forward, and there's then
          no way to bias it to the back.
          t
          • vpilarrt
            • Jun 2006
            • 2096
            Couldn't you install the limiter on the single front brake line out of the master before it splits at the tee?
            • TobyB
              • 5293
              Yes.
              But it will limit front pressure and let rear rise
              right when you want rear pressures NOT to rise-
              when weight's transferring off the rears and onto the fronts.
              It's a recipe for rear- end lockup under heavy braking
              t
              • Massive Lee
                • Sep 2006
                • 6785
                t
                The original MC has a differential piston sizing. Larger in the front and smaller in the rear. Smaller means that for the same effort, it puts out more hydraulic pressure. Therefore, a stock MC shoots more pressure at the rear and the valve limits it to avoid locking rear brakes.
                When using a same size bores MC, my recommendation is to ditch the valve, or otherwise you will end up with not enough rear braking and will be unbalancing the car's braking distribution.
                Allow me to post the same graphic I have made 15 years ago showing how the OEM valve limits the rear pressure vs the front.
                In red is the linear progression without a valve. You can see a knee, and how the rear brake pressure evolves with the valve.
                massivebrakes.com
                • jsta1109
                  • Jun 2015
                  • 172
                  Just to clarify on this point, if you were locking rear brakes with a factory master (318is, 22/19 master) there is a possibility that the valve is no longer functioning correctly? Currently facing this with my setup on track, fronts seem to not function much at all, rears locking quite easily. (my lines are not back to front)
                  IG: https://www.instagram.com/josh.stacey/
                  Flickr: https://www.flickr.com/photos/133952286@N03/
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    It is indeed possible.
                    massivebrakes.com
                    • TobyB
                      • 5293
                      The original MC on the later ABS cars has a differential piston sizing.
                      Fixed that for ya. The earlier m20 cars w/o ABS had a 22/22, and then
                      strangely, early ABS cars seem to have 22/22 as well, switching to
                      the 17/22 roughly around the time of plastic bumpers.
                      I've seen several valve iterations, too, for the different systems.
                      And I've had them fail, too.
                      t
