Anyone see IE's new m20 rockers?
  • JGood
    • Jan 2004
    • 7959
    For $25/piece, it sounds promising! Anyone know anyhting about them?
    Look how much thicker they are, and they are shot peened. Beat's $85/piece for aluminum if it gets the job done...
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • Kilomph
    • Oct 2004
    • 599
    Definitely seems like a good deal, Febi (OEM redesigned) rockers are going for $21/piece, and apparently they only ever break with really high lift cams. That's a $50 difference, really only worthwhile if you plan on running an extreme cam.
    • JGood
      • Jan 2004
      • 7959
      Oh, I didn't know there was a redesign. How do they compare to stock, and these?
      • Kilomph
        • Oct 2004
        • 599
        Originally posted by Stück
        FEBI
        My built m20 with a high duration/lift cam and a 7100rpm limiter did just fine with the revised FEBI rocker arms. There is no one on this board that needs anything more then those in a street car/engine.
        Furthermore said FEBI rocker arms are $18 each or so. Billet rockers are upwards of $80.
        Most e30 owners can barely swing $216 for 12 new OEM rocker arms, let alone upwards of $960 for billet ones.
        The arms are widened, and the crotch is shorter.
        What idiot told you that?
        Took that from bf.c a while ago, so I guess prices have gone up, but I only checked BMA really quickly. They were re-designed in the early 90s I think, and from what I've read there hasn't been a recorded case of one breaking with stock cams and a sane red-line, even after hundreds of thousands of miles.
        • JGood
          • Jan 2004
          • 7959
          wow. interesting.
          Thanks for the info!
          • moatilliatta
            • 6157
            aluminum rocker arms = m50 swap..
            @Zakspeed_US
            • Kilomph
              • Oct 2004
              • 599
              m50 = heavier + far more money + unknown maintenance history.
              • gazellebeigem3
                • Jun 2005
                • 3712
                lawl
                • Kilomph
                  • Oct 2004
                  • 599
                  Originally posted by gazellebeigem3
                  lawl
                  + hardly any faster, if at all compared to the money you'd be spending on the swap could be used for new rockers + chip/cam + lightweight flywheel + exhaust.
                  lawl.
                  • turboeta
                    • Aug 2007
                    • 571
                    No matter how you look at it the M50 is far superior to the M20, although I'm selling my M50 and sticking with the M20...I <3 my 12 valves
                    635csi Euro/Alpina B7S
                    • Kilomph
                      • Oct 2004
                      • 599
                      Far superior if you're willing to shell out a good 4-6k, which would refresh an M20 and build a solid turbo kit. But yes, it's definitely the better engine.
                        • 34844
                        febi rockers here, 7200rpm and no troubles.
                        M50 = *yawn*
                        S50 = :D:D:D
                        • JGood
                          • Jan 2004
                          • 7959
                          This thread isn't about Al rocker arms. I agree, they are way to expensive.
                          lawl.
                          Only by 50ish lbs, and you can find the maintenance history the same way you'd find it for an m20 engine.
                          I spent under $300 on my m50 swap, and it runs absolutely perfect, and pulls much harder then my m20 powered track car that is 300+lbs lighter. If people are spending $4k+ on an m50 swap, they are doing something seriously wrong, or doing a full rebuild top to bottom with parts form the stealer.
                          I do love me the sound of an m20 :)
                          • gazellebeigem3
                            • Jun 2005
                            • 3712
                            lawl.
                            No timing belt, much newer in general and better in every single way, but whatev floats your boat.
                            besides, if you wanted to do it on the cheap, i bet you could swap an m50 into a 325 for under a grand.
                            Sorry to the op, not trying to jack.
                            • Jean
                              • 18228
                              Lol 4-5k for M50 swaps? Maybe 5 years ago.
