street tire suggestions in 15" for auto-x
  • JGood
    • Jan 2004
    • 7959
    Originally posted by madjurgen
    gforce sport tops the rs2 in my book
    In what, tread wear?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • z31maniac
      • 17566
      This is precisely why I went ahead and jumped to 17s.
      www.gutenparts.com
      • madjurgen
        • May 2005
        • 1203
        Must you always be a dick? Look at the tread patterns. Theyre the exact same.
        Ive autox'ed with both and the BFGs feel more consistent over a run, dont squeal and didnt fall off as much toward the end of its life. I even felt that grip was greater with the BFGs.
        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
        • JGood
          • Jan 2004
          • 7959
          Since when does tread pattern effect tread wear?
          One tire is not "better" then another tire when you don't mention what it does "better". Dry acceleration, wet acceleration, dry maximum g holding, wet maximum g holding, responsiveness, sidewall stiffness, tread wear, noise, grip curve, the list goes on... and they are all compromises, one tire doesn't "do it all".
          I wasn't trying to be a dick when I asked that, because from what I've seen that's where the BFG is considered better - tread wear. Along with road noise and comfort. I've used both in competitive environments and agree with the tire rack test results that show the RS2 has slightly better overall handling qualities. Where it lacks is braking (both wet and dry), and tread life.
          • kishg
            • Sep 2006
            • 2624
            Originally posted by nando
            yeah, no. I already have R-comps, don't need to wear a set out driving to work. :p
            ah work.. that.. :)
            haha.. i drive my 540 with S-03s to work :)
            '12 F30 328i Sport Line
            '91 SpecE30 #523
            '00 Ford F-350 Dually Tow Vehicle
            BMWCCA #360858 NASA #
            128290
              • 34844
              S-03s aren't R-comps ;)
              • cheades
                • 632
                They aren't? The new stuff you have coming could be used daily.....
                • guibo09
                  • Dec 2008
                  • 834
                  anything with more than 140 treadwear is definitely not an R-comp. there are 'r-comp' street tires which try to bring r-comp performance to a street tire, but it's not the same thing obviously.
                  90 E30 325i
                    • 34844
                    yeah lol, I may end up having to for a little while until I find a replacement for my KDWs. at least I have a couple spares..
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      I'm actually stuck in the same situation... As soon as winter ends, I need some good summer tires to replace my Potenza G009s (good tire for an all-season, actually). RE01Rs top my book, but they're just the wrong size. The direzzas are apparently very good tires as well, though, but they are also the wrong size...
                      Project M42 Turbo
                      • kishg
                        • Sep 2006
                        • 2624
                        i didn't say they were... :)
                        '91 SpecE30 #523
                        128290
                        • kishg
                          • Sep 2006
                          • 2624
                          I don't think S-03 is even an r-comp street tire (not sure what that is anyways). S-03 is strictly a high performance summer street tire. I was not suggesting they are r-comps. My 540 runs S-03s. My track car runs BFG G-Force R1s which are r-comps. nando got confused.
                          btw, if you can still find them S-03s are an excellent summer tire. I've been on track with them on both the 540 and my e30 and the performance in terms of grip, handling and stability is excellent for a street tire.
                          '91 SpecE30 #523
                          128290
                          • guibo09
                            • Dec 2008
                            • 834
                            what size are you after?
                            90 E30 325i
                            • gearheadE30
                              • Jun 2007
                              • 3734
                              As close to stock as possible, which would be 205/55/15 on 15x7 rims. I would go up to 215 or 225 if I had to to get a good quality tire, with corresponding change in aspect ratio.
                              Project M42 Turbo
                              • z31maniac
                                • 17566
                                No good 225/50/15s?
                                www.gutenparts.com
