Colorado general chat...
This is a sticky topic.
  • Bimmerman325i
    • 6854
    #3031
    Originally posted by Roland H
    Hardly...
    I know, we did it 3 times essentially.
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
    • Bishop
      • 4913
      #3032
      Does anyone have 4 boxes I can have to ship my set of wheels? PM me please, need em asap.
      PM me for detailing services in the Longmont / Boulder Area in Colorado!
      Originally posted by DTM190
      "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
      • Eric
        • 5142
        #3033
        Originally posted by iamcreepingdeath
        Did I ever mention that changing a starter in an E36 is a MAJOR PITA???
        Try on a Euro S50 inside an E30 engine bay!
        Go to any Tire store, I've had an endless supply of wheel boxes by a local tire shop... Probably sold 20 sets of wheels in the last few years and they have never had a problem with me grabbing boxes out of the back.
        • Bishop
          • 4913
          #3034
          Yeah I've called the local places with no luck lol.... I'm gonna keep trying on monday and stuff... If I have to find random other boxes I will, but they hadn't sold any wheels so they couldn't give up boxes.
          • iamsam
            • Jun 2008
            • 176
            #3035
            Hardly...
            PLEASE bestow the knowledge upon me??? It took me six hours (with breaks, lunch, goof-off etc), I took the intake manifold all the way off!!
            I just can't see how it would come out from the bottom. I accessed the bolts from the bottom w/ giant extensions, but how the crap would you ever be able to get the starter loose from the trans, pull it out, and cram another one in solely from underneath?? there isn't room, and besides, how would you ever get leverage on the starter to break it loose from the bottom? The dang starter pretty much sits right on top of the bellhousing!! That's the opposite side from the bottom!
            Do you have a buyer for your wheels?
            • Bimmerman325i
              • 6854
              #3036
              DIRECTLY from the Bentley: "Starter removal and replacement, 6cyl cars with manual transmissions"
              1. disconnect negative battery cable
              2. raise vehicle
              3. remove x brace if so equipped
              4. remove cover from fuel filter/fuel lines as necessary, detach fuel lines and harness connectors from retaining brackets as necessary
              5. disconnect wiring from starter
              6. loosen and remove bolts and nuts fastening starter to transmission bellhousing and/or engine block. remove starter support bracket
              7. remove starter from below
              8. check starter pinion gear and flywheel teeth for damage
              9. installation is reverse of removal
              Moral of the story? Buy a Bentley manual for your car before wasting 6 hours on a 1hr job.
              98 M3/4/5 (stock)
              • Roland H
                • 4480
                #3037
                it's more than a one hour job if you don't have a lift, but definitely not 6.
                • Bimmerman325i
                  • 6854
                  #3038
                  Sure, add half an hour to 45 mins for jackstand on/off.
                  First thing I'm doing when I get my own place: Kegerator and Lift.
                  98 M3/4/5 (stock)
                  • Roland H
                    • 4480
                    #3039
                    and another 30 min or so simply because you work slower when crammed under a car.
                    • Bimmerman325i
                      • 6854
                      #3040
                      That is true.
                      98 M3/4/5 (stock)
                      • monkeytaco
                        • Jan 2010
                        • 882
                        #3041
                        I've also found if you lower the transmission support the extent the bolts loosten without coming off it gives a little easier access to getting an arm+starter out/in.
                        Sorry dude that sounds like a pain. My next house (we are looking) WILL have a lift installed. It is a requirement. (after we buy it of course, unless I find an amazing house)
                        Looking for a clean e30 shell for a project.
                        • iamsam
                          • Jun 2008
                          • 176
                          #3042
                          ok, if we are all done making fun of me now, in my defense, I wanted to take it out from under the car from the get-go, but I guess I didn't see how I would get it from the bottom after some crawling/looking, it looked way too crammed.
                          • Bishop
                            • 4913
                            #3043
                            Yeah, Sam, pending
                            • monkeytaco
                              • Jan 2010
                              • 882
                              #3044
                              At least you were changing the starter and not pulling the transmission to replace a self adjusting pressure plate because you were too dumb to know the difference....
                              • Bimmerman325i
                                • 6854
                                #3045
                                Or pulling the transmission three times because you blew up a clutch slave cylinder and then killed the next TWO of them because neither of us knew they only worked in one specific orientation.
                                I mean, what? Who'd do that?
                                98 M3/4/5 (stock)
