Colorado general chat...
This is a sticky topic.
  • iamsam
    • Jun 2008
    • 176
    #4711
    We should have an R3V gliding day where Alex lets us all use his hang glider.
    • monkeytaco
      • Jan 2010
      • 882
      #4712
      Alex that looks beast. I really want to do it. Let me know when you want to follow an e30 down a sweet road with the hang glider and gopro... :)
      Looking for a clean e30 shell for a project.
      • Cloudbase
        • 1795
        #4713
        Brad where is NREL? The farther away it is, the more challenging the task.
        Ian Mark Windchiemer at Air Time Above Hang Gliding is the best person to learn from. I wish I would have learned from him, he turns out some exceptional soaring pilots. You couldn't be in a more convenient location. You definitely should learn. We could easily fab up a rack for the wagon!
        Once aerotowing starts up I might be able to talk to JR about discounted tandems. I can't make any promises, but I see what I can do. If nothing else a Dragonfly ride might be in order. That would be the best vehicle to chase an E30 with and out east we could do it safely and legally. The only problem or advantage is the the roads are all dirt.
        JOY IS AN E30...
        • blefevre
          • Dec 2008
          • 4287
          #4714
          NREL is the south side of south table. They have a pretty large complex, hard to miss. You can see their vehicle test track on top of STM in your picture.
          - E30, DSM, Golf R, Mazda 3 Skyactiv
          • blefevre
            • Dec 2008
            • 4287
            #4715
            Ian - Splurge and get these for the E39.
            • blefevre
              • Dec 2008
              • 4287
              #4716
              Also, I am totally in for a tandem gliding run!
              • Iannfld
                • 327
                #4717
                http://www.r3vlimited.com/board/showthread.php?t=204880
                Meh, maybe if I had and E34. Too old school for an E39. I just missed out on a set of style 66s on craigslist.
                • Roland H
                  • 4480
                  #4718
                  That can be arranged...
                  • blefevre
                    • Dec 2008
                    • 4287
                    #4719
                    Lol. At least let me drive it first if that's the case....
                    • Roland H
                      • 4480
                      #4720
                      Brake pads should be here by Wednesday. Need to order the fan clutch and motor mounts still. Interior needs re-assembly.
                      • blefevre
                        • Dec 2008
                        • 4287
                        #4721
                        Details. It has a motor, good enough.
                        • Cloudbase
                          • 1795
                          #4722
                          Dudes I got my subframe bushings replaced today. What a PITA. I had a homemade tool I bought for the M Coupe. I ended up using a 6" two jaw puller powered by an impact wrench for extraction and installation. It worked better than my tool.
                          Did my TAB's too. Question - do I need to tighten them under load since they are movement bushings? I've read this on the M Coupe forums. How the hell do you get in there to do that?
                          JOY IS AN E30...
                          • Roland H
                            • 4480
                            #4723
                            Technically it's best to tighten everything you can possibly tighten when the car is on the ground and after you've driven it a few miles. So get it nice and snug, drive it up and down the street, and then drive it onto a set of ramps. and tighten away. If you can't get to it on ramps, just tighten to torque spec +5 and you'll be fine.
                            • iamsam
                              • Jun 2008
                              • 176
                              #4724
                              yes do tighten. I learned this the hard way.
                              • iamsam
                                • Jun 2008
                                • 176
                                #4725
                                So here I am, at 5am doing circuits. And I have to wake up at 7am to drive to school...
