Colorado general chat...
This is a sticky topic.
  • hyperE30
    • Sep 2009
    • 2202
    #6721
    Originally posted by blefevre
    That's fine, I will get all the free stuff then :)
    I was all exited then I remembered I'll be in san diego.
    HyperWerkz
    89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
    " enjoy the show "
    • Roland H
      • 4480
      #6722
      For those that haven't seen. Guten road trip stopping in Colorado.
      http://www.r3vlimited.com/board/showthread.php?t=217883
      Wow, couldn't be more convenient than that.
      Nice try...
      • blefevre
        • Dec 2008
        • 4287
        #6723
        See ya there!
        - E30, DSM, Golf R, Mazda 3 Skyactiv
        • Hansel
          • Oct 2009
          • 218
          #6724
          I'll echo the rebuild vs. reman'd sentiment.
          I just replaced the e30 m3 front calipers I had w/ reman'd. they were like $60-ish a side or something vs. 20ish for the rebuild kit (just the rubber rings).
          I tried to rebuild it first and found
          a.) the piston was rusted so that would've had to be replaced
          b.) the seats for the seals were rusted so the caliper was toast anyways.
          So cost to rebuild eclipsed reman'd cost easily.
          My only issue was the brass guide bushings from the old calipers wouldn't fit into the reman'd ones so I had to use the rubber crap that came on them
          • iamsam
            • Jun 2008
            • 176
            #6725
            I was unaware that the reman'd calipers were so cheap. For some reason I thought they were several hundred a piece. Well, in this case, then I retract my previous statement and my amended statement runs thusly: It is probably worth it to buy re-man'd calipers.
            • Roland H
              • 4480
              #6726
              Yeah, the only thing that left me desiring more with the reman-ed E30 calipers was that the bleed-screws seemed loose. Nothing a good tap couldn't fix with a finer thread-pitch bleed-screw though.
              • blefevre
                • Dec 2008
                • 4287
                #6727
                And with new calipers, lines, hard lines, clutch line, slave cylinder, I FINALLY don't have low brake fluid every other week!
                • Roland H
                  • 4480
                  #6728
                  I'm willing to bet it was your slave that was causing the leak...
                  but your car did need pretty much everything else we did to it.
                  • dubseven
                    • Jul 2011
                    • 382
                    #6729
                    X-Post.... http://www.r3vlimited.com/board/show....php?p=2697179
                    • blefevre
                      • Dec 2008
                      • 4287
                      #6730
                      Improved braking is always worth money/time.
                      • Roland H
                        • 4480
                        #6731
                        fact.
                        • downforce22
                          • Aug 2009
                          • 3192
                          #6732
                          so what would cause my brakes to take a while to build up? For example I brake hard, nice soft pedal car slows perfectly, but if I release and depress again quickly my brakes get very hard.
                          It has always been like this and my mechanic friend said the cam shaft's larger overlap could change the amount of vacuum in the engine meaning it takes longer to build back up. I am looking into a leak in the line from the vacuum on the head to the brake booster, what do you guys think?
                          • Bimmerman325i
                            • 6854
                            #6733
                            Your car is cammed?
                            2017 Chevrolet SS, 6MT
                            95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                            98 M3/4/5 (stock)
                            • Roland H
                              • 4480
                              #6734
                              Originally posted by Bimmerman325i
                              Your car is cammed?
                              I don't know about you, but all of my cars have cams...
                              • Bimmerman325i
                                • 6854
                                #6735
                                lulz. You know what i meant.
                                98 M3/4/5 (stock)
