Colorado general chat...
This is a sticky topic.
  • blefevre
    • Dec 2008
    • 4287
    #7186
    Originally posted by Cloudbase
    Outright jealous.
    - E30, DSM, Golf R, Mazda 3 Skyactiv
    • Bimmerman325i
      • 6854
      #7187
      Alex, your photos and videos are amazing. Gaaaah I want to try hang gliding!
      2017 Chevrolet SS, 6MT
      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
      98 M3/4/5 (stock)
      • iamsam
        • Jun 2008
        • 176
        #7188
        Originally posted by blefevre
        Yep. It is the one downside of having a garage. The power steering, oil, and transmission leaks are starting to annoy me. At least the brake fluid and coolant stays in there now, that's a start.
        Do you know how to get rid of your power steering leaks for good?
        • monkeytaco
          • Jan 2010
          • 882
          #7189
          Step 1. remove ps pump.
          Step 2. drain ps fluid.
          Step 3. profit.
          Looking for a clean e30 shell for a project.
          • Bimmerman325i
            • 6854
            #7190
            No power steering in an E30 sucks. Fuuuuuck that noise.
            It's an easy fix since Brad's already doing an E36 rack swap-- all he needs are new PS lines and reservoir...which isn't expensive.
            98 M3/4/5 (stock)
            • blefevre
              • Dec 2008
              • 4287
              #7191
              Some sort of powerflush with a solvent? Not sure?
              • blefevre
                • Dec 2008
                • 4287
                #7192
                I left everything in place, I just took the belt off. It's been over a year and the rack is still slowly sending some fluid out. Just enough to help make the bottom of the car awful.
                • iamsam
                  • Jun 2008
                  • 176
                  #7193
                  if you drain the rack it makes steering w/ no PS waaaay easier (and it won't leak). And I have had zero problems not having PS in my E30. Of course it is a bit lighter than yours...
                  NOW, when I do an S50 swap and put in a Z3 rack, I WILL have PS, because of the increased weight, and the decreased steering ratio.
                  But for a quick and easy fix for your leak now, and since you already removed your ps belt, you may as well drain the rack, it will stop the leaking and steering effort will be much less.
                  • blefevre
                    • Dec 2008
                    • 4287
                    #7194
                    Meh, no PS is just fine. But PS is much better. I did drain the rack, some just still gets though even now.
                    • iamsam
                      • Jun 2008
                      • 176
                      #7195
                      oh you DID drain the rack. well then, I dunno what to tell ya...
                      you did turn lock-to lock a few times to help drain it, yes?
                      • Bimmerman325i
                        • 6854
                        #7196
                        Driving Ben's and My E30 back to back aggressively pointed out just how much better a PS-equipped car is. So much more pleasant and confidence-inspiring to drive faster when you do have PS. I'm still kicking myself for not installing my spare e30 PS pump when I had the car....I wonder if I still have that.
                        98 M3/4/5 (stock)
                        • blefevre
                          • Dec 2008
                          • 4287
                          #7197
                          Yeah, that's a plus. Really I just want it so I can get a MTech II suede steering wheel. With no PS I would destroy the fabric too fast with the force needed to park. I'm just being picky.
                          • blefevre
                            • Dec 2008
                            • 4287
                            #7198
                            This makes me cry.
                            http://www.autoblog.com/2011/09/29/l...o-u-s-in-2013/
                            • Roland H
                              • 4480
                              #7199
                              Meh, more fuel for the rest of us! :D
                              • iamsam
                                • Jun 2008
                                • 176
                                #7200
                                Woohoo. 37 miles on a charge.
                                but yes, more gas for the rest of is IS good.
