Colorado general chat...
This is a sticky topic.
  • Eric
    • 5142
    #11491
    As much as I hate to say it, I'd take a little airplane over an Mcoupe.
    • Cloudbase
      • 1795
      #11492
      A steel grey / IR & black one in UT sold for high 40's with that kind of mileage a few years back. There is the one in Golden too.
      $60K would buy a high TBO early Mooney or a F'ing tight RV6/7. I'd take the latter.
      A supercruiser is a bit too slow for my taste.
      JOY IS AN E30...
      • Eric
        • 5142
        #11493
        a buddy of mine fresh out of A&P school was building harmon rockets!:crazy:
        • Roland H
          • 4480
          #11494
          Word on the street is that David's Dad's RV-6 is undergoing an annual right now, possible that it will be up on the market soon...
          • Roland H
            • 4480
            #11495
            So uh, anyone want to buy my E30 M3 so I can buy an RV-6?
            Or a LongEZ
            http://www.trade-a-plane.com/detail/...Z/1605719.html
            • Cloudbase
              • 1795
              #11496
              Spent the last two days getting the E46 Sport Wagon up to par. Fuck plastic radiator hose connectors! My car def had 15K oil changes at some point. The PO claimed he did old school maintenance, but he was the second owner. The inside of the valve cover looks like the shit Hans Solo was frozen in.
              Radiator
              Upper and Lower Hoses
              Auto Transmission Thermostat Housing
              Expansion Tank
              Water Pump (the one I got from Bav Auto was bad, but Cal bailed me out with another one)
              Thermostat
              Thermostat Housing
              Coolant Flush
              Serpentine Belt
              Serpentine Belt Tensioner
              Serpentine Belt Idler Pulley
              AC Belt
              AC Belt Tensioner
              Oil / Filter
              Spark Plugs - If there is a little oil on top of the spark plug in the housing is that from a bad seal around the coil tube?
              Power Steering Fluid Flush
              Fuel Filter
              Brake Fluid Flush
              All that's left is the auto tranny fluid flush and filter (not sure if I want to disturb it at 92K miles), diff fluid, and transfer case. I want to install a computer stalk, auto dimming rearview mirror, iPhone adaptor, and program the pax window to tilt down in reverse.
              Reset the Check Engine Light with the bluetooth OBDII plug and the iPad mini. It'll show almost every parameter that goes into the ECU in real time. Pretty cool.
              JOY IS AN E30...
              • Roland H
                • 4480
                #11497
                Radiator
                Expansion Tank
                Thermostat
                Thermostat Housing
                Coolant Flush
                Serpentine Belt
                AC Belt
                AC Belt Tensioner
                Oil / Filter
                Fuel Filter
                Brake Fluid Flush
                If you can change the filter on the auto tranny without draining the fluid, go for it. If not, don't bother. Changing the fluid on auto trannys is asking for things to go wrong.
                • blefevre
                  • Dec 2008
                  • 4287
                  #11498
                  Is anyone going to HPR tomorrow? It's free if you have been this year.
                  - E30, DSM, Golf R, Mazda 3 Skyactiv
                  • griffincox
                    • Nov 2011
                    • 98
                    #11499
                    Radiator
                    Expansion Tank
                    Thermostat
                    Thermostat Housing
                    Coolant Flush
                    Serpentine Belt
                    AC Belt
                    AC Belt Tensioner
                    Oil / Filter
                    Fuel Filter
                    Brake Fluid Flush
                    What OBDII adapter do you use?
                    • downforce22
                      • Aug 2009
                      • 3192
                      #11500
                      what? Dang I haven't been this year. Think I could pass as my twin brother?
                      • Cloudbase
                        • 1795
                        #11501
                        GoPoint BT1
                        JOY IS AN E30...
                        • Eric
                          • 5142
                          #11502
                          You fool me nearly every time, some dude at HPR wouldn't have a clue!
                          • Roland H
                            • 4480
                            #11503
                            Third time's the charm. I hope.
                            • Eric
                              • 5142
                              #11504
                              Ew.
                              • Cloudbase
                                • 1795
                                #11505
                                Shutter
                                JOY IS AN E30...
