shit was crazy on the roads today....be safe out there.
Colorado general chat...
This is a sticky topic.
Lightweight Aluminum Flywheel
Hey,
So as part of the top end rebuild I did on my car, I threw in a new lightweight aluminum flywheel (and new stock clutch/pressure plate). How much shudder should I expect when bedding in the new components. I can already tell that it is getting better over time as I log more miles, but it just seems like it is more than what I would have expected.
To clarify, when I say shudder, I mean going from a dead stop to 1st, when the clutch is engaging, there is a shudder or 'vibration' from what I ascertain to be the clutch and flywheel going between static and kinetic friction. The more revs I give it, the less noticeable it is. If I were to try to do a clutch only start (no revs), it would be uncomfortable to say the least.
Like I said, it is decreasing over time as the two surfaces become bedded, but I was wondering if anyone has some experience with that and can try to explain how much they had right of that bat? I'm at about 100 miles mostly city.
Thanks
1989 325i Alpine White
69 STXComment
FWIW - I'm running a JBRacing 8lb lightweight Alum flywheel in my 02 - and it never 'shuddered' or acted like you described, even when brand new. I don't have an e30 - but what you're describing sounds more like something up with a T/O bearing or clutch slave cyl, or even pressure plate...Comment
I'm running the 8lb JBR flywheel and the FX300 Clutchmasters clutch. I didn't notice anything in the way of "shuddering" from the clutch/transmission. I do have some driveline clunking (probably my driveshaft). That might be worth checking out.All I wanted was a tomahawk....
Ok, guys, thanks a lot, that is really helpful. I also have the JB racing 8lb'er. I'm thinking that it is my pressure plate and that when I torqued it, I had 'phantom torque' where there was enough to make the torque wrench go off, but really I still needed to tighten further until it was all the was bolted on, then torque. That is my best guess as of right now, but I'm sure I will know more after I pop the transmission off the motor.
Thanks for the replies.
69 STXComment
