Trans is back in. Buttoning it up tomorrow :) :) :)
PNW Chit Chat thread
91' 318iS - S54/6MT Swapped
08' E90 M3 6MT - Daily
Originally posted by IronJoe
Originally posted by 2mAn
Brads a standup guy even though he likes buttsexComment
Actually, really nothing, to be honest. Some seals, bushings and a shifting tube. O'Hara pulled it all apart and said that the synchros were great, the shift forks were great, the gears were great.
The problem was being stuck in 3rd gear. Apparently, when you disassemble the trans, you have to get it in neutral. Well, what my problem was, was a little pin that connects to the internal selector rod which selects each gear. The pin somehow bounced and got stuck sideways in the grooves of the rod and wouldn't allow me to change gears. When O'Hara opened the trans, he released the little spring that holds that pin in place and thought nothing of it. Once he screwed around with it for a while, he realized what must've happened.
theres been a long standing group buy over on bimmerforums (in the group buy section, not e30 specific) for brembo rotors. i think i got a set of slotted fronts and slotted rears with pbr pads front and rear for under $400. best brakes ive ever used.
if i was going to do it again id go with full face front and rear with Hawk HPS's.Comment
i had their cross drilleds on my e36. they cracked in less than 90 days. i had a web of mini cracks in between the holes. ill never run them again.
Never heard of Balo. I wouldn't waste my time dude. You've got to pay to play. We drive BMWs not geos!
Brembo and Zimmerman are the big names for a reason. You simply can't go wrong with OEM most of the time. Ill spend the extra to get OEM. My coworkers are the worst of purists.
Running your gas tank dry is a good way to ruin your fuel pump. I just replaced mine. 238.00 for a new Bosch one with my discount. Just food for Thought.clutchCTRL!Move with a purpose.- 1991 325iX 4dr/5spd- 1976 2002 SlickTop/2.7i M20/G260- 2000 323i AT2016 Mazda CX3 Sport AWDComment
