PNW Chit Chat thread
  • cbake82
    • 479
    #25501
    Selling the ix if anyone wants it, cheap too...
    CBAKE
    86 Eta (sold)
    88 325ix (sold)
    87 325i
    • e30Rooster
      • Jan 2010
      • 958
      #25502
      Getting close now
      Sent from my C771 using Tapatalk 2
      • bmwm42
        • 6300
        #25503
        Looks like a beast
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • e30Rooster
          • Jan 2010
          • 958
          #25504
          Looks like a beast
          You should hear the cam <3 instant boner noise
          • kid325e
            • Sep 2007
            • 6421
            #25505
            I can vouch. Its pretty awesome.
            I want to go for a drive right when the leaves start changing color up to Leavenworth.
            clutchCTRL!
            Move with a purpose.
            - 1991 325iX 4dr/5spd
            - 2000 323i AT
            2016 Mazda CX3 Sport AWD
            • HarukoE30
              • Nov 2011
              • 1057
              #25506
              Call me up later or txt me
              Will do; I'll see if Ryan can give it to me.
              Originally posted by ZoomZoomBoom
              I love my full Ground Controls :D
              Originally posted by BraveUlysses
              Me too
              Read good things about them, but I'm slightly confused at the difference of a Full Setup vs the conversion setups others talk about or if they're the same thing.
              Originally posted by James Crivellone
              1) The internet is NOT serious business.
              • ZoomZoomBoom
                • Oct 2012
                • 475
                #25507
                AFAIK, the conversion kit is the spring kit and adjusters. The full coilover setup has Koni single adjustable inserts bolted into the strut housings, Koni single adjustable rear shocks, front camber plates, Ground Control springs made by Eibach, Ground Control bump stops, ride height adjusters, and urethane rear upper shock mounts.
                1989 325iC Zinnoberrot
                • HarukoE30
                  • Nov 2011
                  • 1057
                  #25508
                  So one set you're spending around $1000 whereas the full setup is close to $2k+? Guess I'll start looking at my needs & the benefits between the two.
                  • e30Rooster
                    • Jan 2010
                    • 958
                    #25509
                    Have you heard it with the 280 cam it has now, the one I had before was the 274 and they told me it was the 280, but I got it straightened out now one day ill go megasquirt and get it properly tuned with some headers. Im down for a fall cruse lmk.
                    • ZoomZoomBoom
                      • Oct 2012
                      • 475
                      #25510
                      The full setup is $1500 and the conversion kit is $429.
                      • HarukoE30
                        • Nov 2011
                        • 1057
                        #25511
                        I priced it around $1K, because you need your own shocks/struts I believe.
                        • Twelvizm
                          • Oct 2009
                          • 2108
                          #25512
                          Don't forget about the camber plates while your there.
                          I have GC on the E21, love 'em.
                          • ZoomZoomBoom
                            • Oct 2012
                            • 475
                            #25513
                            This is true for the conversion kit. The full setup comes with them. One nice thing about GC is that you can get a bunch of different spring and damper rates, and if you call them they will help guide you if you don't already know what you want. I would also recommend corner balancing an adjustable setup.
                            • ZoomZoomBoom
                              • Oct 2012
                              • 475
                              #25514
                              Camber plates come with the full setup on the E30, but yeah, you're right about the conversion kit. It's definitely nice to be able to have the adjustments and worth the money.
                              • Habla
                                • May 2004
                                • 1470
                                #25515
                                Originally posted by OldDrunkenSailor
                                Who in the Seattle area is going to the AbeBQ?
                                Meeeee
                                -Peter
                                318is slicktop | F15 35dM | F250 SD
