You are correct. I went back out to put in my new switches. Its still to cold.
PNW Chit Chat thread
For the IX model it get's slightly more complicated. You need the specific transmission, transfer case, & from the research I have seen thus far, suggests getting both IX specific front and rear diff. The transmission/transfer case are the biggest issues and most expensive. Could run into the $2k range for the swap, but I wouldn't mind doing it myself.
Car is listed for $3300, but PO said they take $3k & it has rebuilt head along with $3k into rebuilt auto transmission. Thinking I should probably make a push and just bust my ass this winter finding parts and getting the car up to par for a summer swap.
I am wearing my North Face Jacket inside the house, way too early to be using heat.Originally posted by James Crivellone1) The internet is NOT serious business.Comment
I basically work outside for a living, I'm wearing thermal socks, work boots, top and bottom long johns, another t shirt, work shirt work pants, work coat, and gloves. Still freaking cold.
Originally posted by nwvb bmwThat guy is going to lock you in his basement and make you ware a little pirate costume.Comment
FFFFFUUUUUU
E30 wouldn't start this morning. It was in neutral and I turned the key to crank it... thens topped after half a second because it wasn't in park.
Then in park it wont crank. Like you turn the key and hear nothing. Very strange. I cycle through all the gears and try again, no luck.
The battery read 12.3 volts so it is getting charged now.
I need to check if the starter is getting power... ugh. WHat about the transmission sensor?Comment
Any wind chill up north? I am in Salem so it's off/on rain & I am inside the house ;)Originally posted by James Crivellone1) The internet is NOT serious business.Comment
'70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
it was if you think about it
oh yea, today wasn't as bad since we didn't have real bad wind or snow falling like yesterday but its still colder then a witch's titty in a brass bra.
If you're sure that jumping those pins really bypasses that switch, then it sounds like it's time to start checking relays.'70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
