Jon, I might be down to come help. If I'm not doing anything later, I'll give you a call and come lend a hand!
PNW Chit Chat thread
sweet. Thanks austin, i'll be putting everthing back from the driveline back on down.
SO ready to get this bitch back on the road. lol.sigpic
Currently without an e30. Will probably die soon.
very true but the DME with a fresh O2 sensor should be able to compensate. the injectors are only 17lb were the stockers are 14.5. also the M50 runs higher fuel pressure compared to the M20 so i figure it will be fine. also from reading a good bit on here about the injector swap everyone seems happy with it and says the car seems to run smoother. i don't know if thats a placebo effect or true but its worth the try, and if it runs worse ill pull them out until a get a chip to go along with.
Originally posted by nwvb bmwThat guy is going to lock you in his basement and make you ware a little pirate costume.Comment
same with my WRX swapped impreza wagon, but i went from 375cc's to 880cc's lol
will do, just ordered a set from a member on here as well as the "service" kit for them. im going to also take them to work and clean/flow test them first.
Im scared of this job :(Comment
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
when i did my 5spd swap i had no problem getting both from the top with a extension.
