Alright car still wont start
I tested every spark plug on plug wire #1 ( it is the easiest to see the spark from). All of my spark plugs sparked fine.
Also tested the same spark plug in the #1, #5, #4 and #6 plug wires. Sparked fine still, so I believe my ignition system is fine.
Added gas (thought that maybe someone had siphoned mine). Didn't help anything. When I pulled the plugs though, every single one reeked of fuel, which leads me to believe my engine is flooding.
Now I do not have a way to test the fuel pressure, however my FPR is old and cosmoline all over it (which means it is original to the car).
Should I just go ahead and replace it? I believe I am having the same issue Shean had
Also I should add that the ecu stomp test stills spits out vac leak codes, which means it is still working correct?
I have found this leak, going to ask around for a fuel pressure gauge - http://www.e30performance.info/viewt...d=a&view=print
