PNW Chit Chat thread
  • 5Toes
    • 9836
    #9841
    Well they are controlled by a relay. the k7 relay. Not sure if they have their own fuse
    • shifty
      • Feb 2012
      • 107
      #9842
      Fuse 19 handles aux cooling fan, interior lights, and power mirrors. Relay K7 handles even more than that. If any of those things work, it's wiring or the switch. Turn the ignition on and check for voltage at the connector. If you have voltage, then it's either the switch/adjuster or down-line wiring to the mirrors.
      • OldDrunkenSailor
        • 2271
        #9843
        What's the aux cooling fan? My interior lights don't work in any consistent way, but occasionally one of them will switch on, just not in line with the doors or anything. Worth checking that fuse though, thanks!
        Alpha Team Inductee
        2014 Icon E-Flyer
        2013 Zboard San Francisco Special
        2010 Buell XB9SX
        2009 Harley-Davidson 883 Iron - "Xerces"
        1991 BMW 362iS Touring - "Stephanie/The Death Machine 2.0"
        1974 Honda CB360/CL360 Scrambler Project
        1971 Honda Trail 90 - "Stephen Parish"
        2008 Saab 9-3 Convertible
        2002 Mazda Miata LS
        • 5Toes
          • 9836
          #9844
          Your interior lights likely don't work because the switch on the door is worn out. Speaking of which, does anybody have a writeup on how to replace those little things?
          • shifty
            • Feb 2012
            • 107
            #9845
            That's the "push" fan in front of the radiator that kicks on when a little cooling help is needed. Typically it will run when it's hot out and the car is idling for a while or when the AC is on.
            • OldDrunkenSailor
              • 2271
              #9846
              Ah. I know that that's working, but since my radiator is all fab'ed up, I have no idea from where it's operating exactly.
              Alpha Team Inductee
              2014 Icon E-Flyer
              2010 Buell XB9SX
              2002 Mazda Miata LS
              • HarukoE30
                • Nov 2011
                • 1057
                #9847
                I really need to get that working, but the engine fan has been working just fine even when it was above 80 out this past weekend.
                Originally posted by James Crivellone
                1) The internet is NOT serious business.
                • cbouchez
                  • May 2007
                  • 2789
                  #9848
                  Time to order a guibo, what is the REAL difference between this two?
                  (click to see more)
                  Flex Disc Guibo - 6 Hole - diameter = 110mm - Flat Sides - Genuine BMW
                  Bolt holes are on 78mm centers. 28 mm ... more info...
                  Part # : 26 11 1 225 624
                  $ 124.95
                  (click to see more)
                  Flex Disc Guibo - 6 Hole - diameter = 110mm - Flat Sides - JL GERMANY
                  Bolt holes are on 78mm centers. 28 mm thick. ,
                  Same as 26 11 1 225 624.
                  ... more info...
                  Part # : 51108
                  $ 24.95
                  Follow my IG @bouchezphotography
                  • kid325e
                    • Sep 2007
                    • 6422
                    #9849
                    Few from the shop today.
                    I love my job.
                    clutchCTRL!
                    Move with a purpose.
                    - 1991 325iX 4dr/5spd
                    - 2000 323i AT
                    2016 Mazda CX3 Sport AWD
                    • PNWDan
                      • Feb 2011
                      • 1326
                      #9850
                      Really?
                      Its 1 screw and 1 wire
                      1987 Alpinweiß 325is
                      Like the PNW E30 Local Crew Facebook page
                      • 10Toes
                        Me Father Was A Tree
                        • Jan 2008
                        • 61222
                        #9851
                        Depends on how you wired it but the ls1 ecu can control the aux fan and you can program it to whatever temp you want.
                        • OldDrunkenSailor
                          • 2271
                          #9852
                          Oh, I guess I should have guessed that it was hooked up to the new ECU.
                          I'm not worried about the fan though, just would like to get down to the mysteries of my mirrors.
                          Alpha Team Inductee
                          2014 Icon E-Flyer
                          2010 Buell XB9SX
                          2002 Mazda Miata LS
                          • kid325e
                            • Sep 2007
                            • 6422
                            #9853
                            Anybody see an issue here?
                            clutchCTRL!
                            - 2000 323i AT
                            • shifty
                              • Feb 2012
                              • 107
                              #9854
                              I can think of a couple better ways to reduce weight.
                              • OldDrunkenSailor
                                • 2271
                                #9855
                                The tubs in the first picture aren't stacked particularly well.
                                Alpha Team Inductee
                                2014 Icon E-Flyer
                                2010 Buell XB9SX
                                2002 Mazda Miata LS
