Mother F******g Lollipops
  • 87e30
    • Jul 2008
    • 5676
    #31
    Originally posted by HarukoE30
    t's not the weekend, so I would just take it to a shop & have it pressed, I'm not even bothering next time doing it myself.
    Yep, that's what I did last time. So worth it.
    I just hate everyone.
    No need for discretion.
    • dudecati
      • Jun 2012
      • 104
      #32
      Wait - I am getting ready to do this tomorrow. Are folks saying I should take my control arms and lollipops (which already have had the bushings pressed into) and have the them pressed onto the arms in advance?
      • monty23psk
        • Mar 2008
        • 1289
        #33
        I would never, ever wish this on anyone. If you did this job in under 20 minutes, I envy your control arms. Took me 6 hours & a shitload of laundry detergent to pull it off, so forget the dish soap water, since it will not aid in anyway. It's not the weekend, so I would just take it to a shop & have it pressed, I'm not even bothering next time doing it myself.
        I rather 5 speed swap someone's car versus doing this bushing change any day. May the chariot god's be with you :up:
        If doing the above of taking it to a shop, you need to install it in the car in the next 30 minutes if using OEM bushings whether m3 or non-m3 so that it settles correctly on the control arm. This can lead to the bushing failing prematurely, more so on the non m3 bushings. This is spec from BMW. People do it anyways and have no issue but some have. It has happen to me on my e28 which is hte same principle.
        Alex 88 m5 | 91 318is | 19 Subaru Ascent
        BMW Tool Rentals & Fender Roller
        • monty23psk
          • Mar 2008
          • 1289
          #34
          I would vote against that unless shop it very close by.
          • BraveUlysses
            • Jun 2007
            • 3781
            #35
            No, DIY it. Hammer and sil-glyde (available at NAPA). Done.
            • isamemon
              • Jan 2009
              • 257
              #36
              since others are having trouble and there has been reference to a home made tool, I tried the search but could not find it...anyone have that link...this would be a good time for it
              as for me,, the last time I did mine, a little sanding on the CA, dish soap and muscle
              • dudecati
                • Jun 2012
                • 104
                #37
                OK - thanks all for the pointers, sol-glyde, sandpaper and muscle will all be on tap!
                • 87e30
                  • Jul 2008
                  • 5676
                  #38
                  Click my name, click view public profile, click view threads started by XXXX. Helpful forum hint... the very first link is the thread I made.
                  This is the post in there:
                  I'm sure the proper tool is much better, but did what I could with the local hardware store supplies on the cheap.
                  This was a while ago, like I said I just had the standard style bushings pressed at a shop as that is much much easier. I hope the bushing doesn't prematurely wear but honestly as a centered design and as they are pressed on at the proper orientation I'm hoping it should be fine. I know you're supposed to set the car down within 30 minutes, but let me tell you it can be hard to get both sides done manually within that 30 minute window... so I took it more as a guideline.
                  If you read a lot of these threads many people say they can slide them on with: force, hammer, laundry detergent, fairy dust. For me there was NO WAY that bushing was going on with anything other than a press/extreme force tool. Moral here is apparently some CA and CAB combinations can work out differently than others.
                  • HarukoE30
                    • Nov 2011
                    • 1057
                    #39
                    Originally posted by ser1992
                    I removed mine, cant get the new ones on... help me, before i just kill myself.
                    Im in seattle, I just saw the install tool online, I do not have one..
                    Yes I did forget that part when advising so thanks. I could barely walk let alone think after my second one was on, but I kept saying out loud "drop the car, drop the car, drop the car."
                    Originally posted by James Crivellone
                    1) The internet is NOT serious business.
                    • ser1992
                      • Feb 2013
                      • 482
                      #40
                      So i built a tool and finally got them on!!! but... when i was torquing the bolts down, one broke off at 50lbs..
                      all the other ones went in fine, im just wondering if the car will be ok to drive to a shop so they can replace the bolts?
                      • nickmcc92
                        • Dec 2012
                        • 442
                        #41
                        pics or didnt happen.
                        i honestly wouldnt try driving on it but you should befine. try putting a lug nut on there
                        • ser1992
                          • Feb 2013
                          • 482
                          #42
                          and correction not 50lbs, 50Nm
                          yes.. it fawking broke.. Im going to limp it to a shop to replace the bolts when I find a good shop.
                          • ser1992
                            • Feb 2013
                            • 482
                            #43
                            has anyone had one break? I hope it will be fine putting along for a day..?
                            • 87e30
                              • Jul 2008
                              • 5676
                              #44
                              One of the lollipop bolts? Dang that sucks. You could always drill out and extract, luckily it's a pretty easy location.
                              • e30austin
                                • 15382
                                #45
                                I had one break. Drilled it right out.
