Mother F******g Lollipops
  • ser1992
    • Feb 2013
    • 482
    #46
    Ok... Ill continue this DIY from hell. Are there any good guides for drilling out broken bolts? I've never done it, but if it is half as fun as installing the CABs it should be a great time.
    • 87e30
      • Jul 2008
      • 5676
      #47
      To be honest I tried once in high school (so many years ago) and was unsuccessful. I'd definitely look at getting a good kit, that should help. Otherwise just google it.
      I just hate everyone.
      No need for discretion.
      • nickmcc92
        • Dec 2012
        • 442
        #48
        It's called a screw extractor. It has reverse threads
        • slowe34
          • Sep 2011
          • 206
          #49
          There are several types of extractors. I like this style, especially with a lager bolt, like you are dealing with
          http://www.amazon.com/Irwin-Industri...sxp_grid_i_0_1
          If you have never done it. Go slooooooow. Use a punch to make a center mark on the broken bolt. Work your way up in bit size when drilling your hole and USE LUBE. If you want those bits to cut and last more than one extraction, use cutting oil. And remember they are reverse bits. Drill spins backwards
          After you have a hole, tap that weird looking spiral bit in and use a wrench to turn. Boom you're done.
          But if it broke at 50Nm, it will probably come out when you are drilling the hole
          • TobyB
            • 5297
            #50
            a thousand dessert suns
            Does the dessert sun go to the left or the right of the dessert spoon?
            heh
            t
            • LJ851
              • 7919
              #51
              heh
              t
              Classic.
              Lorin
              The M30 is God's engine.
