Supercharged S52 w/G260 swap. Complete from radiator to exhaust $5K
  • Pipes
    • Aug 2012
    • 485
    Hello all,
    I am considering going a different direction with my car. What would be included is absolutely everything you would need to swap a beastly supercharged S52 into an E30. I bought the car a little over 2 yrs ago with the S52 installed but only test miles on it. The engine had 83K on it with a new top end and a new oil pump (welded nut). I've been driving it 2 1/2 yrs working out all the bugs, and in that time replaced the water pump and alternator with new heavy duty Bosch items, replaced every conceivable gasket, did a Dr vanos kit, swapped in a Euro HFM/TRM chip/injectors, and lots I'm forgetting. In that configuration the car made 233hp at the wheels (dyno sheets available (uncorrected was 242hp)). Last Fall I purchased an Active Autowerke Stage 1 Supercharger kit, which included a Rotrex blower ( ~7lbs boost), oil cooler, resevoir, lines, chip, and injectors. With the SC installed it made 299hp at the wheels on the same dyno (carb connection in Kirkland), but had some detonation at the top end, so I've since gotten a different chip. It no longer has detonation so I presume it makes more power, but I have not had it back on the dyno. A month ago I blew the head gasket between cyl 5 and 6. Kevin and Tom at KD Motorsports took it all apart, inspected it, and sent the head out to be checked. The block was fine but one of the pistons has a couple of small dings on top; the insulator on the spark plug fell into the combustion chamber and bounced around before I shut down. The head checked out perfectly but it was decked to ensure it was absolutely true, and then the engine was reassembled using ARP head studs and an MLS gasket. There is now a new radiator, thermostat and temp switch, and the oil filter housing has aeroquip provisions for an oil cooler, although it is just a loop at the moment. I've been driving it a month and oil temp never gets above 200 even in stop and go traffic. Water temp never goes above 3/8 on the gauge. Does not leak a drop of oil.
    So, why am I selling? Basically, I am tired of breaking things. With this much power I have already had to replace an axle and three guibos, and the diff is making noise. Right now the stock clutch/pressureplate is beginning to slip in second gear at 5000rpm if the pavement is dry (used to spin the tires), so it really needs to have a sport pressure plate and sport clutch installed.
    What would be included: everything.
    1998 S52 engine with 96K, new top end w/ARP headstuds & MLS gasket
    OBD1 swap
    Euro HFM
    New water pump
    New alternator
    New oil filter housing
    all new gaskets
    New plugs
    New thermostat, hoses
    Dr Vanos vanos kit
    30 lb injectors
    Supercharger oil cooler w/E30 mounts, oil reservoir w/E30 mounts
    ECU with custom chip
    New belt
    New tensioners
    all Supercharger plumbing to fit an E30
    Headers (new studs and gaskets)
    Full custom 2.5" exhaust w/cats (passes with flying colors). Finished with a gorgeous black Vibrant twin outlet muffler.
    New M42 radiator w pusher fan wired to temp sensor (never even gets to halfway on temp gauge)
    Engine mounts
    G260 5 spd w new UUC Evo3 shifter mechanism (shifts beautifully)
    Tranny mounts
    Price: $5000. Basically, $2000 for the Supercharger kit and $3000 for the engine and trans and absolutely every last thing needed to install this in your E30 (although I do recommend a sport pressure plate and clutch)This pic is prior to the new radiator:Click image for larger version
    1991 349is (wadded up)
    1984 Rabbit 2.0L16v swap (wife's)
    2003 LR Disco II (wife's)
    1993 MB 400SEL (son 1's)
    1980 MB 450SEL (son 2's)
    2004 KTM 525 EXC-R SM Sold:(
  • 2mAn
    SeƱior Mod
    • 20207
    smoking deal! What will you replace it with??? Spill the beans!
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • hoveringuy
      • Dec 2005
      • 2686
      I saw it on the rack at KD. Beautiful looking motor!
      • Pipes
        • Aug 2012
        • 485
        Thanks! It's a fun ride. Anyone who's interested I'm happy to let them drive before purchase. I can't say what might replace it until the deal is a little closer to done...
        • LuckyHenriksen
          • Jun 2010
          • 4244
          Awesome deal man, GLWS! I would love to pick this up but I don't know what I would do with it haha
          Bahama Beige E23 Project
          Bluebird Bus Conversion
          New Oregon Trail
          • Pipes
            • Aug 2012
            • 485
            I'd prefer to sell locally if possible- you drove it when it first arrived so know the setup......it would fit nicely in your cab..........
            • cleanasse30
              • Jan 2014
              • 436
              Do you have any videos of it driving or pics of the engine bay?
              2.7i Stroker Turbo Build Thread
              90 325i | 95 Miata
              • Pipes
                • Aug 2012
                • 485
                I drive it every day so I can certainly take some pics/video.
                • Pipes
                  • Aug 2012
                  • 485
                  a couple of vids
                  I took a couple of brief phone videos this morning: a cold start and an entrance ramp. You can see that it has plenty of power: 20-95mph in about 5 sec even with massive wheelspin as the power comes on in 2nd. It was a bit awkward videoing and countersteering at once; sorry for the poor quality. But you get the idea.
                  Cold start: http://youtu.be/q0cin0Wr-MA
                  Onramp: http://youtu.be/XiG708qI0as
                  • hankolerd
                    • Oct 2012
                    • 280
                    Originally posted by Pipes
                    That is just lovely.
                    Daniel
                    1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
                    2011 328i Sport Wagon - 6sp Manual, RWD, Sport
                    • e30josh
                      • Sep 2004
                      • 718
                      wow, very nice!
                      what throw out bearing/clutch kit is used?
                      • Pipes
                        • Aug 2012
                        • 485
                        Stock E36 M3 dual mass flywheel and clutch kit.
                        • Pipes
                          • Aug 2012
                          • 485
                          Probably good this hasn't sold; other side of the trade fell through...
                          • Pipes
                            • Aug 2012
                            • 485
                            Bump. Found what I was looking for to go in there....
                            • e30austin
                              • 15382
                              I was just thinking about this last night. Still don't wanna let go of the boost stuff eh?
