E30 M50 swap shifter carrier offset issue
  • e30strokr
    • 211
    Hi
    Need some help/advice
    1988 SETA 325
    Im almost done with my M50 swap however the shifter carrier sits way off to the passenger side barely being able to shift to 5th, there was never a mention of this being a big deal..
    I have done
    Garagistic delrins on the front of the shifter bracket
    Garagistic 24v 10% offset DSSR installed
    tranny mounted with only the 4 big bolts, starter installed
    I cant shift the motor/tranny enough for the carrier to be workable
    also cannot fully hook up the back of the carrier to the car/bracket in the rear since its offset
    I did add around 10mm of spacer on the passenger side motor mount ( green M5? motor mounts) with no change, but now the lower exhaust fits :)
    what am i doing wrong here?
    thanks for any comment/help
  • Vincenze
    • Apr 2019
    • 1028
    The engine is tilted differently compared to the M20.
    It's a known fact.
    You may look at changing the transmission too.
    • e30strokr
      • 211
      It's a known fact.
      yes it is a known fact the tilt is different hence the mention of the offset DSSR, and I was expecting some offset but not this bad to not be brought up in the 100's DIY M50 swaps I looked thru before starting this swap
      many use the G260 without a shifting issue...
      • Vincenze
        • Apr 2019
        • 1028
        When they use the Getrag 260, they cut and weld the shifter carrier.
        Check topics similar to this one.
        • e30strokr
          • 211
          apparently but never mention.. now i see this.. its going to be a pain to remove the carrier since adding the delrin it was hard to put back on and that was with the tranny out... well see,
          thanks for the link
          • Vincenze
            • Apr 2019
            • 1028
            thanks for the link
            That simple hack won't work well as bolted connections will flex.
            There are companies that can weld aluminum things.
            • mjweimer
              • Dec 2015
              • 648
              Unfortunately many of these little details are not mentioned in swap threads. Even with the ZF320 the typically mentioned shift carrier options don't really center the shifter and create 5th gear issues (not to mention it looks funny).
              I had to get my hands on a used shift carrier to cut up and use that material for an offset.
              Pics in this post:
              • e30austin
                • 15382
                make sure the shifting arm you are using, is from an '87+ 325i, and not an ETA unit. they are different. 325i is offset to the RH side of the car, ETA unit is straight.
                • e30strokr
                  • 211
                  Pics in this post:
                  https://www.r3vlimited.com/board/for...60#post9937460
                  kinda glad im not the only one to say it but , the motor and tranny is in!! more delays and summer is almost over..lol
                  thanks for the link to the built thread, love seeing others do a better tidy job..lol
                  • ZinnoSuperEta
                    • Feb 2024
                    • 24
                    Yep I retained the G260 in my M50 swap and to get the shift carrier to line up I just heated it up near the center of the beam part and twisted it matching the 10 degrees of the selector rod. It's not perfect and doesn't put it right in the center but it works and its free
