S52 question
  • blown9746
    • Apr 2022
    • 9
    S52 question
    So I was told my car was swapped with a 99 S52 with OBD1 intake, but still OBD2. I know the intake is OBD1 style. My question. How to tell if it is actually running OBD1 or 2?
  • 2mAn
    SeƱior Mod
    • 20701
    What ECU is it running on?
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • ForcedFirebird
      • Feb 2007
      • 8300
      Easy tell is where the crank sensor is. If it's on the timing cover, it's OBD1, if it's on the back of the block, down by the starter, it's OBD2.
      john@m20guru.com
      Links:
      • moatilliatta
        • 6148
        Or OBDII had a hole in the block by the starter for the crank sensor. M52/S52
        I have an OBDI block running OBDII with the Euro crank sensor.
        Head gasket should say 3.2 on it by the T chain tensioner.
        @Zakspeed_US
        • blown9746
          • Apr 2022
          • 9
          Thanks. I checked the DME VIN and it is from the 99 M3. Now to find if / where they put a diagnostic port
          • eternal24k
            • Jul 2017
            • 507
            you may not have an OBD2 port, but an OBD1 to OBD2 adapter works
            • ForcedFirebird
              • Feb 2007
              • 8300
              You mean the round diag port? You can actually just jump a couple wires and skip the adapter.
              john@m20guru.com
              Links:
              • eternal24k
                • Jul 2017
                • 507
                Can you elaborate? I have always used an adapter since my scanner has OBD2 plug, so I have an adapter to plug into the round OBD1 port to read my codes. Curious what you're doing
                • eternal24k
                  • Jul 2017
                  • 507
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    The scanners only need to see power, ground and k(l)-lines. Those adapters just jump those corresponding wires.
                    Basically, I have a home made version of this: https://www.teewigo.com/ping-obd2-di...18-obd-break33
                    This not only allows me to scan swapped cars that never had an OBD port installed, I can bench flash ECU's as well.
                    john@m20guru.com
                    Links:
                    • eternal24k
                      • Jul 2017
                      • 507
                      ok gotcha. For $11 to get the round plug adapter, I will just keep going that route
