e30 m50 swap - emmissions testing
  • Brew
    • 3060
    Mine passed a few years ago no problem with 24# inj, 540 MAF, e30 cat. No more sniff tests in MA as of last fall, though. Yippee.
    '91 318is
    • russiane30
      • Dec 2008
      • 46
      i have 24lb injectors 540 maf 3 inch pipe with magnaflow cat and TRM dyno tune and it didnt work so of i go to fine some nice guy that can make it happen ;)
      • e30s52
        • Oct 2007
        • 5235
        What chip do you have? I have to pass the sniffer test.
        www.gutenparts.com
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          emissions testing? whats' that?:giggle:
          • surebimmer
            • Jan 2004
            • 978
            Originally posted by matt
            Did you email me about this? If so I replied today. Sorry, I was at the track all weekend.
            There is no reason you can't pass emissions with the mods you want on your car, you just need to have it running well, have a good cat, and have a tune for the mods.
            I was the one that emailed you. The mod's I have on my car are S52 OBD 1, 24lb injectors 3.5 inch MAF, LTW flywheel, K&N air filter, OBD 2 exhaust manifolds, Brand New One mo. Old Magnaflow CAT. Brand new 02 Sensor, 74* T-Stat.
            Pre-tested my car at work before i went to the CA Bureau Of Automotive Repair (BAR).
            Only thing I did differant for the 2nd test was replace my iridium sparks plugs with stock copper ones. Fresh Oil change, And put a bottle of Clean Power in my tank. Clean power is mostly Toluene so i think is just raises the octane rating.
            Do you think I should run the stock 80* T-stat?
            Also thinking of going back to a 3 inch MAF and 17 lb injectors.
            • matt
              • 3732
              Originally posted by e30s52
              HC limit is 150 mine was 320
              CO limit is 1 mine was 9.7
              CO=CO2 limit is 6 mine was 18.3
              Can you post a scan of your results, please?
              • matt
                • 3732
                Try a bottle of HEET next time, and see if you can get them to run the 15mph test in a lower gear. You are really close.
                Did you warm up your cat really well the second time?
                Edit: Are you running a 3.5" MAF and 24s with a stock chip? If so... go back to stock MAF and injectors.
                • surebimmer
                  • Jan 2004
                  • 978
                  Running a Turner Chip for said mod's.
                  • matt
                    • 3732
                    Did you warm up your cat really well? Your results look like an inefficient cat.
                    Don't fuck with your MAF and injectors unless you change the chip also.
                    • surebimmer
                      • Jan 2004
                      • 978
                      I need a new chip for the sliver label 413 that has the 95 M3 vin on it. I'm telling them the motor is from a 95 M3 so I don't have to run all the obd 2 stuff. I did warm my cat before the test.
                      What about a warmer t-stat?
                      • matt
                        • 3732
                        Might help a little, depends on how that chip is programmed.
                        If you're in warm-up mode at that temp, you're getting a rich mixture (High HCs) and possibly advanced timing (high NOx)
                        • russiane30
                          • Dec 2008
                          • 46
                          i dont have a chip Machoi from TRM did a dyno tune
                          • Brew
                            • 3060
                            Conforti.
                            '91 318is
                            • markseven
                              • Sep 2006
                              • 5327
                              I was being specific as the first three posters in the thread are all in the Atlanta area. I freely admit that I don't have the first clue what is required in other areas including CA, but I believe the actual values for emissions are federally mandated, so if it passes a sniffer in GA it will pass in CA also.
                              I was searching for cats today and saw a bunch of '49-state' units and some that were 'CARB Approved'. I think CA still has more stringent (and getting more so every day) emission control parameters than any other state.
                              Is there a certain model from MagnaFlow that all y'all like for an OBDI S52? This one is $154
                              I Timothy 2:1-2
                              • Danny
                                • 14216
                                Fuck California.
