Are you interested in doing a 24v swap? Read this!
This is a sticky topic.
  • 2mAn
    SeƱior Mod
    • 21017
    #136
    Originally posted by c0rbin9
    Does a 24v swap into a 1991 318is require any chassis modification, i.e. cutting off brackets or anything? Basically I'm wondering if this swap is fully reversible.
    Yup, the only thing I can think of that might be "unreversible" is getting the wiring harness through the firewall hole usually needs to be enlarged slightly, but its all easily covered
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • c0rbin9
      • Dec 2015
      • 609
      #137
      Okay, thanks.
      1991 318is Brillantrot daily driver (slow restoration)
      • pazi88
        • Sep 2015
        • 584
        #138
        If someone is interested of doing the wiring harness modification by themselves, I made a video about that: https://www.youtube.com/watch?v=euxmWXAJg9U
        It may miss some obd2 stuff like CEL wiring because we don't have those in use here.
        • ZekeTheSneak
          • 1562
          #139
          The wiki link is dead.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #140
            318is and 24v use the same sized ECU connector. From what I know, the only ones that require opening the firewall hole is the early models (86 and earlier). The Motronic 1.0 and Jetronic used the smaller ECU connectors.
            john@m20guru.com
            Links:
            • turboplzz
              • Nov 2016
              • 13
              #141
              the new link has been posted 3 times in the last 2-3 pages
              • TeXJ
                • 1914
                #142
                Do I need to use a tune with a m52b28 swap? DME red label 413, ebay headers, exhaust with no cat, K&N intake.
                Have a mechanic that thinks my idle issue is due to there not being a tune for the car.
                He says there is a vacuum leak but thinks that's not causing my issue.
                1990 325is
                m52b28
                3.73lsd
                g260 (1987 325is 5spd tranny)
                • TeXJ
                  • 1914
                  #143
                  ^bueller...
                  1990 325is
                  m52b28
                  3.73lsd
                  • JGood
                    • Jan 2004
                    • 7959
                    #144
                    Vacuum leaks are basically the number 1 cause of idle issues... it’s pretty much the only thing they cause.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • TeXJ
                      • 1914
                      #145
                      I agree. But I also had an issue with the CEL coming on complaining of the O2 sensor. O2 sensor has been replaced multiple times. Wiring has been checked.
                      The car also had a weird issue where when you start to rev the motor that at about 2500 rpms and up it sounds like a 2-step.
                      1990 325is
                      m52b28
                      3.73lsd
                      • JGood
                        • Jan 2004
                        • 7959
                        #146
                        Vacuum leaks can cause O2 codes due to mixture issues. If you have a vacuum leak, that is very likely your issue. It should be fixed regardless.
                        • TeXJ
                          • 1914
                          #147
                          aww good point. The vacuum leak was with the PCV valve.
                          1990 325is
                          m52b28
                          3.73lsd
                          • GabiJohnson
                            • Mar 2020
                            • 4
                            #148
                            just do add: You dont need to replace the 36 oil pump with the e34 oil pump if you're doing an m50 swap, the pumps are the same part, you just need the oil pickup tube. It makes life a whole lot easier and saves you money
                            • LowR3V'in
                              • 4209
                              #149
                              whats the best brake booster to use? there are several ppl are using and people are moving the booster to the side.
                              • tkeenan
                                • Jul 2009
                                • 45
                                #150
                                I recently replaced an e21 booster that leaked with a Porsche 944 booster, which I got new at a pretty reasonable price. Not worth going used imo. Easy to fit as well.
