I must be missing something when searching the wedophones for the c101 connectors, the c101 in my 1991 318i has 16 wires going to a 20 pin connector so I figure I should find all 16 c101s, but I am only finding 7.. any suggestions? I have read through all 49 pages of the wedophones multiple times.
Are you interested in doing a 24v swap? Read this!
This is a sticky topic.
Something that may be worth noting if it hasn't already been is it looks like some S52B32's (and I can assume M52's) have all three holes drilled for coolant ports in the head. One of them is blocked off with a plug and the other two hold the OBD2 temp sensor and TB coolant port. The third hole has a larger thread diameter that I am hoping will be a match to the e30 sender, the other two appear to be m12's. Engine and car are both 09/96 according to casting stamps on head and the VIN tag
1990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice peopleComment
So alloy blocks, and I'm guessing on N/A cars there are a few months after the switch from M/S50's to M/S52 where they still drilled all three holes. I was preparing myself to drill/tap, delete TB heating etc and this saves me from any hack workLast edited by Varinn; 05-20-2013, 09:43 PM.1990 332i, 4 door
2017 Mazda CX-5 GT
I have a weird question. I have an 84 325e. And I just bought a complete M50 swap that was originally in a 95 525i. But in 1997 the M50 was swapped into an 87 325. And that's how I bought it. So, after reading a lil bit, The body connecter is different, (round vs square pin), than the 84. So how do I go about swapping it into my 84? I'm having a shop do this, so I'd like to make this as straight forward for him as possible. I thought I read there's pre made adapters from someone on here?84 325e Burgundrot S52 M Tech 1.
http://www.r3vlimited.com/board/showthread.php?t=250109Comment
Get in touch with 328i junkie on the board or go to his website at Markert Motorworks and have Dave build you a harness. It will cost a few bucks but I keep hearing about all the positives of going this route and wish I would have done the same.1990 332i, 4 door
2017 Mazda CX-5 GT
There's a few of us who make harnesses/adapters, but if you are having a reputable shop do the work, they should not have an issue with the connector.I have a weird question. I have an 84 325e. And I just bought a complete M50 swap that was originally in a 95 525i. But in 1997 the M50 was swapped into an 87 325. And that's how I bought it. So, after reading a lil bit, The body connecter is different, (round vs square pin), than the 84. So how do I go about swapping it into my 84? I'm having a shop do this, so I'd like to make this as straight forward for him as possible. I thought I read there's pre made adapters from someone on here?Comment
In the process of buying an M50B25 from someone that does swaps in the UK, so I have to ask a lot since I'd have to sort out freight and what not. So I decided to ask the guy about the additional parts required, and listed the parts on the main post of this thread and he came bake with the following differences:
E28 motor mounts - E24 USA Mounts
E21 brake booster - He says he uses another but didn't specify
The engine is being supplied with the standard 5-speed manual trans, he says E30 M20 mounts should work for that.
Has anyone had experience with any of these with their swap? Or can shed some light? I won't doubt the guy, I'm sure he knows what he's doing but I just want to see what you guys think.
EDIT: Now I'm seeing most of the differences are also interchangeable...Comment
If it's from a 92 325 it's a Non VANOS m50. S50 was only in 95 M3 in the US. I wouldn't expend the time, money and energy needed for an M50 Non vanos swap personally.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
Yeah okay thanks for the heads up! I definitely want an s50. How hard is it to source one? And how much do they usually go for?
Sent from my iPhone using TapatalkComment
Being offered for such a short time the s50's are harder to come by, you might consider an s52, they are more common and you get a little extra displacement to boot.Comment
Got dayum. I'm tired of my m10 lol. Is there any difference in the s50 from the s52
