Header selection ? for M50 swap
  • madjurgen
    • May 2005
    • 1203
    Originally posted by bejbis
    I have the obd2 headers. To make them fit better, I cut the front header about 3 inches from the flange and clocked it so it wouldn't point straight at the subframe.
    -Dan
    I like this solution. What are the OBD2 headers made of, SS? I'd like to be able to do it myself but I only have a MIG welder. Any other modifications you had to do to get them to fit?
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
    • bejbis
      • Dec 2008
      • 596
      I apparently didn't have to clock them, as other forum members have used them without problems. I just didn't like the look of the bend that would have to be made to clear the sway bar and subframe.
      They are made of stainless. I welded them with a TIG. And yes, all i did was cut and clock them, if i had to guess, about 30-40 degrees counterclockwise if you are looking at the flange.
      -Dan
      • rThor432
        • Feb 2007
        • 3907
        Originally posted by FredK
        Those look like Genie headers to me.
        http://forums.bimmerforums.com/forum...d.php?t=797696
        I agree. They don't look like the Ebay specials. The 3-1 merge on the Ebay rep headers is much further down the line near the firewall if not right at it. Those look like they'd clear well in an E30, FWIW.
        • FredK
          • 14762
          Genie headers do not clear the firewall in an E30, as I found out the hard way. One of the post-collector pipes interferes with the firewall. It clears the front subframe fine, though.
          I'll be cutting and welding my set.
          • 7pilot
            • 475
            Originally posted by hoveringuy
            Were they the same as the SS reps or did they have $1000 quality?
            I'm also seriously considering the CARR shorty headers. The M54 is a strong low and mid range motor so these might suite me well..
            I don't think the headers in your first pic are SS at all.
            m
            • z31maniac
              • 17566
              I'd get the Turner ones if they weren't $800. Is it worth getting really good collectors on shorty headers??
              The TMS are A.W.E.S.O.M.E.
              Except putting them on and taking them off. 11mm angled ratcheting wrench will be your best friend.
              www.gutenparts.com
              • Gnarles
                • Dec 2008
                • 342
                I just started fitting up my exhaust this past weekend and the obd2 headers mate up with the obd1 mid-section with out any modifications. I just had to lift the engine slightly to mate them up. They cleared the subframe by about 0.25".
                • FredK
                  • 14762
                  I have a 140A MIG and at the time I tried to plug the header flanges, I was very inexperienced at welding. I'm a little better now, so I know with plenty of preheat that I could lay down a bead that'd be good enough to plug the channel, using stainless wire.
                  • xwill112x
                    • Jan 2009
                    • 4236
                    why does everyone do headers with their swap? more power? or do the e34/e36 ones not fit?
                    • Voluted
                      • 104
                      OBD2 manifolds have clearance issues...but for OBD1? Baller status?
                      • xwill112x
                        • Jan 2009
                        • 4236
                        hell yea, marked headers off the list. using e34 headers so i have more cash for fuhraze parts :)
                        • z31maniac
                          • 17566
                          Mo powa.
                          Well if you buy QUALITY headers. I wouldn't be surprised if some of the cheap eBay knock off stuff didn't do help at all.
                          www.gutenparts.com
                            • 34844
                            ebay headers tend to have crappy collectors and primaries that are too short (and probably too big), but they're cheap and shiney so everyone buys them.
                            • FredK
                              • 14762
                              Eh, the OBD-I downpipe has a terrible collector as well. It's a smooshed piece of pipe with probably the effective ID of a 2.0 to 2.25" OD 16ga pipe.
                              I think the Racelands are proven to add power.
                                • 34844
                                of course they do, all OE manifolds have junky collectors. But at least they're cheap/stock, and they fit. :p
