Bad Thermostat?
  • Danny
    • 14216
    Bad Thermostat?
    So when I'm driving my car will heat up to about halfway between the half and 3/4 marks. Then after a 10 maybe 15 seconds it'll drop right back down to the half mark, like the thermostat is taking too long to open. The highest its ever gotten while doing this was the 3/4 mark.
  • Adrian_Visser
    • Jun 2006
    • 2823
    You mean hot starting Or when starting cold it just keeps heating up? Or do you mean it heats up in stop and go traffic?
    '89 Alpine S52 with goodies
    • Danny
      • 14216
      It'll happen under an conditions, all though it happens more frequently at cruising speeds, or so it seems.
      • xwill112x
        • Jan 2009
        • 4236
        are you running any engine fan?
        • Danny
          • 14216
          Nope, but the e-fan is wired to be on at all times.
          • Dj Buttchug
            • Jun 2010
            • 7680
            replace/ drill thermostat. re bleed the cooling system
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
              • 34844
              why? you're sucking HP all the time when you don't need to. get a thermoswitch. they're like $20.. :p
              • Danny
                • 14216
                Shit I dunno. It was easier than doing all that.
                • xwill112x
                  • Jan 2009
                  • 4236
                  i dont have any fan on my m42 car and it kinda does that on long cruises on the highway, but not as hot of temps. it creeps barely up to the middle mark then back down again, and repeats.
                    • 34844
                    what, plugging the fan into the stock aux fan wiring and changing the thermoswitch? lol :)
                    • Danny
                      • 14216
                      Its kind of a long story. lol.
                        Is the car loosing coolant? If so you may be seeing overheats/overpressure from a small head gasket leak. That will form a bubble in the cooling system, causing the engine to run hot. When the pressure gets high enough the cap lifts, venting coolant and air and the temp comes back down.
                        • MR E30 325is
                          • Dec 2008
                          • 3300
                          I am with this guy.
                          My previous build (currently E30-less)
                          http://www.r3vlimited.com/board/showthread.php?t=170390
                          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                          • Danny
                            • 14216
                            Yeah its losing coolant, but I attributed it to a slow leak instead of a headgasket.
                            that's bad news.
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              that's bad news.
                              If its a slow leak, then when the coolant gets too low the temp will go up, thermostat opens, and the temp goes down.
                              The same exact thing happened in my E30 when i had a 318is rad trying to cool the M50. Exact same symptoms as you.
                              I swapped in a 325is cooling system, and I was much happier, and the problem disappeared.
                              Check your coolant level when it starts doing it. If its really low then you have a pretty bad leak.
