It is either idling before that range, or it cuts off after/during that range. Otherwise it feels like it lack power.
Switched ECUs and same symptoms.
Out of the countless people I have spoken to, you are probably the one that knows the most about this problem. You are exactly right, the car runes fine with the Vanos unplugged. When vanos plugged in "The cam advances too much" as quoted by the shop. And he said exactly that; the valves are just barely impacting the pistons. The only thing that stumps me is that my cams are stock. I am sure the shop timed my car properly in the factory method, so why does the problem continue? Unless I have a Schrick intake cam and dont know it.
